oil around top of barrel.
https://forums.aussieveedubbers.com/threads/28394/oil-around-top-of-barrel
BiX ·
on sunday while i was down under the car i noticed that i have a oil leak between the cyclinder head and the barrel. I normally give the engine a degrease every 2 weeks to make cams ppl happy at races, so there is normally very little oil ont eh engine. It occured on teh right rear cyclinder, what could cause this?
seagull ·
head stud loose ?
Buggyboy ·
Bix you got mail...
seagull ·
been thrashed in a large open grass area in second gear ?:thumb
Loose head nuts, pulled stud, or poorly machined heads.
pick one of the above ^ !
BiX ·
mmm that all just sounds expensive. But yes seagull, that could be the cause:thumb. I will have a good look and see what i can find. The engine only hs about 30k on it and was rebuilt early 01. so its only just iver 3yrs old. Mabye its time for a strip and rebuild 🙁
[Edited on 8-9-2004 by BiX]
did you find the problem?
