Your Carburetor Linkages need to be Lubricated at every oil change.. or sooner..
They used to be done with every oil change at a VW service centre in the 50s & 60s... along with Your VWs door hinges , engine cover & bonnet lock & hinges..
I believe that everything that moves , wears, and that the wear - can be either be stopped all together - or at least slowed down...
Its probably the simplest lubrication job ALL owners of Air Cooled Volkswagens can do... Even You can do it...
So, If it moves, lubricate it... a simple drop of oil onto each moving part... will do the trick... and Your VW will love You for it... its true...
Lee the Lubricator...
