Staplin wrote:Hey there,
I have a '62 body on a '69 floor pan. The '62 body didnt come with a fuel tank and my 69 fuel tank doesnt fit. Should I modify to get it to fit or just get a 62 tank? Also the 62 body doesnt have a fuel flap on the side.........So I'm thinking to fill a 62 tank up you must have to pop the bonnet right? If someone could post a pic of a 62 fuel tank it would be appreciated
Scott
Scott,
Up to 1967 the tank was filled by lifting the bonnet - the fiiler neck is in the top/front of the tank, and the tank has a raised rounded front edge.
From 68 onward the tank got a little flatter (the raised front edge is lower) and the filler is on the outside of the car (how do you tell a 68 from a 69 at one glance - the 68 has a finger indent on the outside filler and the 69 doesn't - it has an internal pull-wire release.)
Just one of the approximately 2000 changes made to VWs each year!
So since you have a 62 body you'll have to get the earlier style tank, and you'll have to lift the bonnet to fill it up. Oh - and since you will be lifting the bonnet a lot, have a look at the bent-under lip up the sides of the bonnet - some bonnets have a reinforcing strip welded behind the fold-under so it won't crack across the lip (and eventually across the whole bonnet). It's a simple job to get a reinforcing strip welded in there if your bonnet does not have it.
