Aussieveedubbers 路 Tech Talk
Electronic Ignition
https://forums.aussieveedubbers.com/threads/28579/electronic-ignition
voltz 路
recently purchased an 82 model Kombi 2.0 efi air cooled and would like to fit electronic ignition, has anyone had experience with the aftermarket kits or am I able to use a complete unit from another model
Also in need of various rubber seals and a sliding door latch for the beast,recommendations for some parts suppliers please
While Im at it Id like to grab some information regarding building a new engine with view to carrying out some perfromance mods, any sites that explain the various barrels , heads , cranks etc ?
I see many different names of products but have no idea the good or the bad 馃槈
Regards
voltz
71superbug 路
i would not mind wat kits are out there for electronic ignition?
as i am going turbo and wouldnt mind one
lugnuts 路
http://www.tunacan.net/t4/ and http://www.shoptalkforums.com/ its all there dude use the search and enjoy 馃檪
Klaus 路
I bought a kit from Wayne Penrose V.W bit over $200
brand is Pertronix , american made PER-1847. Installed it over 15000kms ago and haven't touched it since, best piece of mind ever installed.
It fits directly into standard dizzy and takes about 15mins .
matara 路
Classic Veedub who sponsor the forum are selling Compu-fire kits on special at $64.99!!
Bizarre 路
THAT is CHEAP!!! :beer
james(DNVK) 路
You can order the pertronix kits directly from the U.S for less than $200
tassupervee 路
voltz wrote:recently purchased an 82 model Kombi 2.0 efi air cooled and would like to fit electronic ignition, has anyone had experience with the aftermarket kits or am I able to use a complete unit from another model
Regards
voltz
Errrrr dude, your EFI engine already HAS electronic ignition...............\
L8tr
E
tassupervee 路
Regards
voltz
L8tr
E
johny rotten 路
*82 EFI type 2 c omes std with points, your best bet would be to use a dizzy etc from a 83-85 vanagon or T3.
voltz 路
tassupervee wrote:[
L8tr
E
As a mechanic I can tell the difference between points and electronic ignition 馃檪
My engine is not fitted with it
Perhaps they came standard with electronic ignitiion ( I dont know)
Regards
tassupervee 路
Farrrkkk then dude, thats a new one on me then.........efi engine with points for buggerys sake.:duh
Ill take that one back then..............consider gob shut!
L8tr
E
voltz 路
no worries
the more I find out about this vehicle the surer I am that the engine is not original, mine has adjustable tappets whereas Im led to believe this model should have hydraulic,I might visit the VW dealership on Monday and try and find out exactly what should be original equipment
tassupervee 路
M8
Good luck widdit!
l8tr
E
