I tried searching but didn't find an answer. Would I see any benefit in replacing the current fans in a Kombi (which I do not have yet) with bigger and more power full fans?
Thanks,
seagull ·
Kombi have one fan ( 1 ) , you could fit a oil cooler would be better option if your pulling a load or in a hot place
Silver_Platinum ·
How hard would it be to implement a oil cooler into the Kombi?
Can it be done by myself?
seagull ·
You can buy a oil cooler kit
the kit has a adapter that has fittings for the hoses to go on to .
the only problem is the ( stock oil cooler is removed )
if you sit in one spot ( say at the lights ) the motor temp will rise , owners do fit a electric fan that comes on via a temp switch as the heat comes up , this works .
I would say if you did not have the skills to fit a * full flow oil filter and cooler * via tapping the case > this would be your best option by far .
any one else ??
