Here are a couple of pics of what it looked like before and now in the middle of the carnage..Photos taken with my phone so understand the quality issues.
Matt
[Edited on 25-9-2004 by boof2332]
boof2332 ·
another.
boof2332 ·
Back removed....
boof2332 ·
fire wall removed....
boof2332 ·
Slots cut in the front panel. Smeared with bog and in the process of being rubbed back and sprayed..the smear covers the little inperfections caused by the grinder. Alfa 33 radiator tucked in behind with 2x 10 inch thermos. Aluminim sheeting covering with a rubber edged raised section that seals off the area when the bonnet is closed. The rear has been chopped away behind the radiator so air can be sucked through...thus the sealed boot space.
Jak Rizzo ·
Hey, Matt, or Boof 2332, or should that now be Biff EJ20T, u shouls be ashamed of yourself! taking a perfectly good Wolfsburg example & destroying it's very foundations of which it was designed apon!
That goes for the rest of u siko's as well,
What I want to know is who the hell authorised this part of the forum anyway!
AIRCOOLED FOREVER,
Jak
wacked1 ·
Jak you gotta be joking
:jesus
wacked1 ·
boof that is looking cool. what engine, gearbox you runing.
wacked1
Those Aero guards do stand out...
Nice job on the Beetle....
Nice phone 🙂🙂
unusual pics...
First time I've seen phone pics...🙂
VolksFolks ·
Whatever jak, looking good bring on the photos, intrested in the outcome..
Andy
Jeza ·
Matt
Good work- I like the slots in the front apron- much more subtle than a huge hole!
How tight is the fit? I thought Wes and Seagull etc mentioned the ej20t was too long to fit in the Beetle engine bay? Are you shifting the gearbox forward at all?
Any width issues with those quad cams?
I guess the firewall re-fabrication is for the inlet? I thought some people were turning the inlet around? Or was this only on the NA versions.
Jeremy
Jeza ·
Jak Rizzo wrote:That goes for the rest of u siko's as well,
AIRCOOLED FOREVER,
Jak
Stirrer!!!:thumb
seagull ·
Looking good Matt I love the stance of the front real cool .
Does the radiator have an air blead line for the top of the tank ?? you will need to run that to you fill pot on the WRX donk .
I think the lads would like to see the mounts for the gear box as this moves the unit forward , I would like to see as well as to copy them 🙂 I can make them 🙂🙂🙂
love to see those big boots smoking and hear that turbo sound
Guys were can one get those aero guards please ??
lugnuts ·
Tell him Dave,stuff it since im here and hes in snuggleland and ohh whatever,u guessed it vintage had the aero guards.:P
lugnuts ·
More pics more pics and BETTER ones BETTER ones :kiss
pete wood ·
Seems to me that Jak is scared....
he's about to have his little aircooled butt kicked when boof is done.
Sorry Jak, but even porsche is over aircooling.
come to the dark side jak, the water is strong in you, you can feel it, you know you want to...
:vader
wacked1 ·
thats funny
boof2332 ·
Hey Jak,
I will forgive you as you have not yet met me!
Post the recent pics of you car.....who is going to tell them you or I????????? How did today go?
The gearbox in the car is an L bug box with welded 3rd and 4th gears and a superdiff.
The front mount is a berg one which moves the box 2 inches forward. I will try and get a pic....
The ej20t fits....had it in last week with no flywheel or clutch to fabricate the piping to intercooler.
The fire wall was removed for the turbo and exhaust and also the throttle body and intercooler piping which will do a 180 degree turn back and up where the sti cooler will sit in between the deck hinges and stand offs...with shrouding around it. To its left will sit the ram pod in a aluminium box with a fresh air pipe maybe out the side of the deck.
There was more cutting to get the engine in....just behind the bumper brackets is where the cam covers sit. I am probably going to chop the last two gaurd bolts off and make a bolt on frame with the rear apron attatched which the gaurds will attatch to as usual. Will be done next week.
Got a IHI vf24 ball bearing turbo yesterday(sti upgrade turbo) from the states...will be here monday...then back in she goes, wire up the microtech and away we go..
Will post pics as soon as possible.......
Matt
Boof2332
Biffej20t
seagull ·
can I see the fuel pot that bloke made you !
seagull ·
so the turbo you are removing would be a good buy for some one it of a import auto correct ?
Hi Matt
Looking good.
Drill a really small hole in your thermostat, this will aid in getting rid of airlocks. I did this on my WBX and I could fill it at the back and it would fill the whole system no worries, no need for an air bleed on the radiator then, bit hard to fit anyway when the motor is at one end and the radiator is a the other end of the car . Just make sure your fill point is higher than the radiator and use a an overflow bottle, this will help expell any air after the 1st few warm ups cool downs.
Jeza ·
Matt
Thanks for the "fit" description - fantastic
Sounds great. I assume the new turbo ups the power output some more... 206kW not enough :thumb
Keep us updated
Jeremy
type2nut ·
Steve,
could you explain further your statement
"Drill a really small hole in your thermostat, " please?
boof2332 ·
Hi All and Jak,
Got a mig last night and a heap of steel yesterday, so will be fabricating the rear subframe and new mountng points for the gaurds etc....
have to wait for the new turbo before I can put the motor is, as it sits at the back...bugger.
This magician also made me a swirl pot and fuel filter....guess who?????? Whick looks awesome.I will post a pic, and that can go on also.
Oh, the boys want to rub it back and paint it this week as we have to blow in lots of little bits here and there, my mate wants to just paintthe whole thing! COLOUR???????
I was thinking black....what do the people say?
Matt
The reason for this is to allow the water to flow to both sides of the thermostat when filling and before starting the motor, otherwise your trying to fill the motor and expell air pockets behind the thermostat via the back door. The small hole has no affect when the motor is running. Some OEM (not VW) thermostats have a small ball valve to achieve this.
boof2332 ·
Well today the car has ben totall rubbed back and all the nicks and scratches filled and is ready for primer on monday.
I love spur of the moment decisions....pics from today....
Gaurds off ready for rubbing.....
boof2332 ·
Being pussed out side....verry messy and wet...this wet and dry experience...
boof2332 ·
All done back in the garage ready for the spray.....
boof2332 ·
This is where the back has been totally removed and the rear apron bolts back on in the centre with the gaurds attatching either side.....
boof2332 ·
oh and the engine......note the sti cooler will sit up at the back....
Thanks for the interest by the way guys.....appreciate the posts....
Jak Rizzo ·
Matt,
I think that it is still not too late to turn back, after all , whats a vw without a vw engine in it?
regards
Jak
AIRCOOLED FOREVER!!!!!!!!!!.............what the hell am I talking about?
lugnuts ·
Hey boof,hows it goin,great pics mate but can u makem BIGGER BIGGER,thanks dude :kiss
lugnuts ·
Jak Rizzo wrote:Matt,
regards
Jak
Err,faster and quieter and reliable (ducks for cover and scurries away):blush
56astro ·
regards
Jak
Depends on who builds it, hey?
If ya get someone who actually knows what they are doing, then it comes quite easily.
On the other hand, if ya have no !@#$%^& idea then ya have to look for alternatives.
boof2332 ·
My vw stroker motors have always gone like rockets...only reason I sold the 2332 is because Doddy was going to look at the bits for another year and I wanted the car on the road.
Rumour has it Jak was never happy with the power or lack of it his 2275 made....
Reason there are little photos is because I am still using my phone....convenient.
Matt
lugnuts ·
boof2332 wrote:My vw stroker motors have always gone like rockets...only reason I sold the 2332 is because Doddy was going to look at the bits for another year and I wanted the car on the road.
Matt
Matt,no problem dude we can wait :kiss
lugnuts ·
regards
Jak
I always thought if u have no !@#$%^& idea yude better buy one from someone that does :duh
[Edited on 26-9-2004 by lugnuts]
boof2332 wrote:Rumour has it Jak was never happy with the power or lack of it his 2275 made....
Matt
Wow ..............never heard that rumour.; LOL
Jak was always promoting how great the combo was :duh
[Edited on 27-9-2004 by Craig Torrens]
boof2332 ·
A little update.....For those interested...
The car was done in primer today and will be rubbed back and finished in the next day or two. The motor will be back in by the weekend with the harness all wired up...
Here are the painting pics...
