Aussieveedubbers 路 Tech Talk
This is an easy one (how to replace h/brake cable)
https://forums.aussieveedubbers.com/threads/29133/this-is-an-easy-one-how-to-replace-hbrake-cable
Desert Moose 路
Can some one please remind me how you replace a set of hand brake cables in a 63 bug, I don't have the car here and I'm going to do it for a friend on the weekend.馃檪
PS.....She has one of the nicest bug's I have seen in a long time and I'll try to remember to take a pic馃檪
vw54 路
remove hubcap
undo 36mm nut with a F B socket and bar remove split pin first
loose wheel nuts
jack up car and put on jack stands
rattle n remove rear brake drum and wheels
undo 13mm bolt on inside of backing plate.
use pliers to pull cable end off brake arm
remove hand brake boot and undo 10mm nuts
remove old cables
I had better follow these instructions tomorrow as i am replacing both cables on my 65
seagull 路
* brake dust * wash it away with water
Desert Moose 路
vw54 wrote:remove hubcap
loose wheel nuts
remove old cables
Thanks, I do remember all this but isn't there a catch to putting the cables back in the tunnel:thumb
seagull 路
yes get some one else to do it , while your having a beer :beer
vw54 路
sometimes there a little short so u have to yank on them with long nose plies when fitting to the hand brake cable.
U might need someone else to fit the nut and its a good idea if you remove one of the seats in order to fit cables to hand brake lever.
I suspose it took me about 2 hours today to fit my new ones,
