Dreaded foam removal
https://forums.aussieveedubbers.com/threads/29261/dreaded-foam-removal
Does anyone know of any way to remove the horrible foam that VW stuck in later Beetles? Does anything dissolve it short of a nuclear blast.
barls ·
oxy makes a short job of it. a piece of coat hanger does wonders as well
Hi Barls
Does it keep smoldering when you burn it? Dont want to have a Viking funeral.
barls ·
it goes out eventually but you may want some one in side to keep the flame under control with a spray bottle of water
nicko ·
I have heard petrol may dissolve it. I have not tried it out.
Try some acetone or paint thinners... it will disolve the glue...
Other than that hook into it with a strong bit of hook wire remove the headliner will make it easier.
Easy! Pull it out through the rust holes it causes in the rear roof...
(No idea, apart from a flame and coathanger)
MickH ·
acetone will disolve it
mnsKmobi ·
1302Steve wrote:Hi Barls
Viking funeral - I like it! Wouldn't you have to be sailing into the sunset?:thumb:thumb
