3rd fuel line on Subaru motor
https://forums.aussieveedubbers.com/threads/29262/3rd-fuel-line-on-subaru-motor
Does anyone know what the 3rd fuel line on the WRX motor is for? Do I tee it or block it?
barls ·
its not the return line is it
No it has 3 lines grouped together, I would assume 2 are inlet and return, not sure what the other ones for.
barls ·
no sorry steve i havent had much to do on a wrx but ill ask my old man when i speak to him later
555bug ·
i'm not 100% but it may be the return from the charcoal canister to the tank.
speedster356 ·
Had to ask the same question Steve when the WRX went in. See here
http://www.rslibertyclub.org/forums/viewtopic.php?t=6177&highlight=
[Edited on 27-9-2004 by speedster356]
Baja Wes ·
you need a password to access that forum
PS - my guess is carbon cannister. My V6 had it's mounted near the engine.
speedster356 ·
Yeah the canister, that line runs to the fuel tank vent.
Baja Wes ·
yeah. I ran two new 8mm lines for the fuel feed and return. Then used the stock VW small fuel line for the fuel tank vent.
carnt you do with out the cannister or do u need it for redgo... i would block it up
555bug ·
you must keep all pollution controls
Baja Wes ·
yeah, you have to run whatever emmission gear the motor came with. In my case a carbon cannister and a cat. The carbon cannister is so small anyway. Mine's smaller than a coke can.
baybuscamperkid ·
would this be the same on other earlier engines? i have 3 similar lines from my engine (ea81). one isnt hooked up and at the moment the engine will only run for about 10sec before it dies of lack of fuel, would the 3rd line to the cannister solve this?
