Item :2 x Solex carbs P11 40mm
Cond :require service
$100.00
+ freight
need to clear these
[Edited on 2-10-2004 by seagull]
[Edited on 7-1-2005 by seagull]
[Edited on 31/3/2005 by seagull]
seagull ·
bump
seagull ·
any one , need for a 356 ?
greedy51 ·
i have 2 of those maybe they could use 1 for each piston
just a idea
joele ·
are there manifolds available to fit type 1?
with a little work they would fit IDF manifolds
seagull ·
yes correct , need to remove a small amount in the center of the IDF manifolds , have done this in the past .
joele ·
and how do they perform?? any problems?
seagull ·
well I would say like a set of 40mm webers , the quality is there .
seagull ·
bump for me I have no need for these guys .
seagull ·
bump
vassy66T1 ·
Are the carbs a pattern that suits a dcn manifold?
If so, I would be interested in some more pics.
thanks vassy@coolcats.net.au
They are the same as IDF's
The olny difference is the pump actuator hangs down low and you need a clearance between the 2 "throats" of the manifolds.
vassy66T1 ·
Thanks for your reply.
I am not interested then
cheers😀
new manifolds might be cheaper than a carb :thumb
by the way - for anyone that wants these
There is a place in the states called Doc & Cy's (800) 950 0356
They sell rebuild kits for these for about US$15
That is a very good price even including a rebuild kit from the states that would cost no more that the exchange rate plus less than $15 shipping with no duty or GST.
Someone in teh know will buy
seagull ·
I dont have a need for them , some one must have a project that requires these .
Special Air Service ·
Will Webber linkages work on these or are they going to need a custom job?
Doug Sweetman ·
If I didnt already have a set of 40IDF webers in the shed I'd be keen.
But I never got the webers running as it was anyways !!
