Any cheap front disc upgrades up your sleeve ? Can you do the same thing up front with Ford floating discs etc ?
waltermitty ·
hi seagull, do these change the wheel track? if they do do u know by how much?
Regards Mitchell
The mounting surface of the wheel on the disc with Falcon rears is the same - or within a few mm - of stock, so no it doesn't change your 'track' (dependent, of course, on wheel selection)
Doug Sweetman wrote:Good price neil.
I will be saving my pennies !
Working on this as we speak !
seagull ·
Blue , this is a close as a kit as you will find that fits .
doug , The front disks will come allong when I find a bug , 15 window to do it to.
walter, what vwcool is saying is true
Jenny ·
Good price Neil! (free bump)
If you already have front disc brakes then you can get new front disc rotors in Ford stud pattern fron V Force in Sydney, mine were $290 pair plus $18p/h to BNE and were fitted with studs.
seagull ·
bump
Jenny wrote:Good price Neil! (free bump)
this will only give you a "standard" brake setup in ford pattern. What I'm working on is a non standard brake setup e.g. ventilated disc and larger caliper.
seagull ·
this is the rear disk and hub ( all in one from V force ) they can drill the PCD what you require ( not wide 5 ) on this disk .
photo *
The ford disk can be drilled and the hubs top of page are blank
as for bigger caliper vented disks , we all are not race car drivers Craig , just would like disk brakes 😉
[Edited on 29-10-2004 by seagull]
seagull ·
bump
seagull wrote:this is the rear disk and hub ( all in one from V force ) they can drill the PCD what you require ( not wide 5 ) on this disk .
photo *
:thumb Craig doesn't need brakes for his hillclimb car... because brakes just make him go slower! It's the stupid, silly, sick 220km/h road Bugs hanging around at Craig's house that need a beefy vented front disc...
Doug Sweetman ·
I was mainly thinking about brake balance given that your rear discs would then be larger diameter, larger pad area and larger pistons than your fronts. Thought it might make it a bit taily under brakes.....
That's why you fit bigger, fatter, beefier, stickier vented mofo brakes to the front! 😉
[Edited on 15-10-2004 by VWCOOL]
Alex Holzl ·
Hey craigie we already have a FAT ASS vented, crossdrilled rotor with alloy hub and alloy caliper thats is that much lighter than a vw caliper you begin to wonder wat is in the vw caliper. My brother has these on the front of his car and im doin them for mine now. His brakes are AWSOME!!
alex
seagull ·
GET your own add ALEX!😀
lol...
Alloy brake parts.... big $ and no legal rego...
seagull ·
Price drop
Special Air Service ·
will these fit swing axle beetles or just irs?what bolt pattern are the disks drilled for?how is the front to rear bias affected?:duh
seagull ·
yes , read the post ,no
hubs are blank,I got that but the discs are drilled arent they?ford patern or what?:blah
Alex Holzl wrote:Hey craigie we already have a FAT ASS vented, crossdrilled rotor with alloy hub and alloy caliper thats is that much lighter than a vw caliper you begin to wonder wat is in the vw caliper. My brother has these on the front of his car and im doin them for mine now. His brakes are AWSOME!!
