its prob been answered 100 times before but i didnt find it in a quick search so:
is a compufire ok with a gt40 coil. ??????
thanks anyone...
Anthiron ·
i think i heard somewhere that u would have to use a standard coil as the GT40 gets to hot but i could be wrong. someone else will know
Hmmm... i cant remember now - but there IS a difference.
When i put my Magfire in it said you wanted a coil with
a) 1 ohm
b) 3.5 ohm
resistance.
Buggered if i can remember which one it was :jesus
fetid_swamp ·
hokay then, another qu.
how many ohms resistance is a gt40 or which terminals do i use to measure its resistance.
do i go across the + & - or do i involve the HV dizzy lead somehow???
straight across the pos and neg
fetid_swamp ·
I will check it & advise. thanx.
fetid_swamp ·
gt40 will be no good.
it says i need a high impedance (resistance) coil of 3-5 ohms not one of 1 or less ohms.
just tested it and the gt40 has a 1 ohm resistance.
so anyone have any ideas on an appropriate replacement??
yeah - the BLACK bosch coil
NOT the standard Blue Coil
Once upon a time so,e one posted here that they worcked for Bosch and the different coils were resistance related
Blue - points
Black - electronic
I think the serial is SE 12
yep - Its a SU 12
Black and is 3.5 ohms
I just measured it
manx020 ·
i have been using a 009/compufire combo with a bosch gt40 12volt coil for years with no problems.
cheers,
rick
fetid_swamp ·
thanks all.
i think i will still get a high resistance coil in my next order from a forum sponser as it's better safe than sorry and i can keep the gt40 with the points and condenser in the spares kit to cover any electrical fry action far from home.
[Edited on 5-10-2004 by fetid_swamp]
Baja Wes ·
I had a compufire equivalent (magnafire?). First I ran it with a GT40R, but it overheated after 20min of driving and stopped. was ok once cooled down. The GT40R is meant for cars with a ballast resistor.
I then went to a GT40. Never had a problem since then. (eventually sold that motor).
A Sports coil such as the GT40 - draw substantially More current than a standard ignition coil...
to obtain their higher output voltage.. which can result in overheating...
It may depend on where the coil is situated , such as under a closed engine lid [without vents]
... or under a late model engine lid with vents - or open at top etc.. or Baja...
What do you want to know? Removing the resistor in the rotor is supposed to be required if you have a high output ignition such as a CDI. Otherwise the resistor overheats and stops conducting.
Anthiron ·
can you not just buy a rotor with a bigger resistor? you would think they would manufacture something if this was a standard problem.
cool. so the resistor in the rotor is not something we need to worry about if only going to a compufire and not a full blown CDI system.
thanks
Good job,
that rotor won't burn out...
I did buy a new rotor without the resistor from the US..
Was more than double the price of the original VW rotor..
Everyone should carry one of these for a spare...
especially if You have a High Energy electronic ignition system..
A local had one burn out a few months ago...
Had to be towed home....
His father found the problem...
The rotor burnt out while being driven...
so, it can happen....
PS. I do believe there is a replacement rotor from a different car that does fit the Air Cooled VWs distributors...
with NO resistor....
Grey 57 ·
I fitted a compufire unit into my old oval fitted with 1600 SP. The standard Bosch Black coil died in a very short time. It has to do with the duration of dwell. Perfect with a hall cell. I.e. the points (hall cell) are on (closed) a longer time between opening. This cased the standard coil to over heat.
Changed to a Bosch electronic coil (non ballast resist) and had no more problems.
The Compufire unit is money well spent on a VW engine. Starts faster, idles smoother, dunno about extra power never checked it on a dyno. Saves pissing about with points every 3000ks too.
