I had a wheel, with a brake drum bolted to the back of it, not on a car, and the bolts were done up extremely tight.
Normally, if the wheel was on a car then you would just use a breaker bar and some wd40.
But without the wheel on a car it was free to turn around as it pleased, even with me pushing it up against a wall with my knee or foot.
So, I went to the tyre shop and they couldnt get them off with their air tools.
Finally I worked out that all i needed to do was stop the wheel from turning and then i could use the breaker bar.
Solution: Chain the wheel to a tree, in one of the indentations between branches or roots.
After this the wheel could only turn slightly, after which it was stuck and i could apply enough force to get those bolts unstuck.
And the tyre shop said it wasnt possible!
*did* ·
