anyone in Brisvagas have a broken microwave?
https://forums.aussieveedubbers.com/threads/29691/anyone-in-brisvagas-have-a-broken-microwave
555bug ·
The bigger the better really, 1000w is what I'm after. Broken is best as its probably free or free ish. Oh and it is car related...sort of,
Stephen
Lams ·
oh... thought you were going to fix it for me :P
Andy ·
You''ll find plenty at the tip, or any suburb with a road side clean up 😀
MikeM ·
Microwave powered Kombi in the works?
Dave will have one.
555bug ·
Bueller, .... Bueller.... ?
Adam_C ·
can i ask wat this is for, im intregued? (Sp?)
XXX-1.8T ·
dont u know its for his flux capacitor😀
Tazz ·
GREAT SCOTT!!!
:P
Tazz
555bug ·
I'm making a spot welder but need more current 🙁 I'm shooting for 1000Amp :bounce
fetid_swamp ·
beutiful. absolutly beutiful.
karmen ·
hot stuff
karmen ·
hot stuff
koolkarmakombi ·
Do tell more, this looks interesting.....
555bug ·
hmm well first off its dangerous, a microwave transformer will kill you dead without hesitation 🙁 that said use your brain and you will be right 🙂 all thats required is to remove the secondary windings from the transformer and to replace then with your own. In my case I'm running four loops or 4# wire 100amp rated ( 4v due to 1:1 turns ratio) which works out to be lots of amps...well a few.. but not enough as it turns out so I'm hooking up a second MOT and then I should be good to go. I have visions of a portable unit for working on cars but that will depend of the final KVa i can acheive. If i survive i'll do a page for my site which i'll link to.
Stephen
koolkarmakombi ·
If you die, can I have your Rex ?? :P
JOKING!!!!!!
Man you will push some serious power with that pair. Hope you wear rubber sole shoes....
Check out the old posts there was a link to the dude using the new alternators to TIG, he had a fair few other ideas on the go like this (had made a plasma cutter too)
kkk
DoNkEy ·
go to the BCC website and look up kerbside and find out where it is this week....and then take ur pick.
There is literally thousands of em...i should know ...i am cheap and check out all the piles when they are local:blush
koolkarmakombi ·
so did you die???
