vw0064 its on the other bit like barls said and u will c it next year aswell, thats if i dont get another 1
BiX ·
I run the autotechnica bos and don't have a problme they are probably 150mm long? and with the momo race wheel have no problems (would be nice to be 50mm longer, but thats cause i have short arms!!!)
DIY-DUB ·
so u wouldnt wanna swap then
This is a common problem with all aluminium steering wheel bosses...
I have made a spacer from another boss... and I know of other people who have done the same thing because the boss isn't thick enough and the steering wheel is too flat...
The steel bosses are long enough.....
BiX ·
Nope i like my race wheel. and the boss kit is ok. Is yours the earlier boss or the later (during the superbug era they changes to teh golf boss size)
DIY-DUB ·
Problem kinda solved all i need now is slightly longe bolts 4 a bit more bite, ive made a spacer if you are interested, i think mine is a steel 1 not aluminium, its way 2 heavy 4 it 2 be, it looks like cast iron on the outside 2, now i just gotta get the horn bit 2 work properly
DIY-DUB ·
problem 2 horn shorts out on coloum every 1 elses ive seen has about a 3mm gap how have u done this??? mine sits flat on the thing
jonno-t3 ·
i dunno if this helps...but i modded a sports mazda wooden wheel by drilling out the orig spline....then i cut my old vw wheel up turned the vw spline down to size(slightly larger than the mazda hole) then using a 3 tonne press, i pushed it in....works a treat..
jonno
Many people put a push button under the dash on in the dash for the horn.... as the boss kits etc can be a problem..
If they work its usually good luck....
You can get longer bolts from bolt shops,,,,,
Stainless steel Allen headed screws look good and don't tarnish or rust...
