I am considering using EFI (either Delco, or more likely Microtech) on my next engine. I will use two IDF-style TBs, Commodore/Bosch injectors with a Weber-style linkage... does anyone have ideas where I can start looking for TBs?
[Edited on 20-10-2004 by VWCOOL]
56astro ·
Here is a start!
There are some good links from these sites as well. From what I've learnt about EFI the single throttle body design is better for tune-ability. quad throttle bodies do work, but better vacuum signals with single TB and plenum.
thanks for that. I'm investigating a remote-mounted IAC pumbed to the two IDF throttle bodies - all GM (probably Camira) stuff tuned using Kalmaker on a double-plugger. Would prefer dual TBs rather than one for airflow/power... although I do have a Camira/Bosch TB here I could play with... I think it's about 60mm... The cam I will use (I think you know from who...) gives good steady idle vacuum.
56astro ·
It has been said that this intake design is pretty close to ideal.
The price is a killer though. Far cheaper to calculate the figures and design your own.
speedster356 ·
Have a look at the Suzuki Hyabusa TBs. They are flanged the same as Webers (IDFs I think) A mate has a set on his Alfa powered hot rod. They generally come with injectors and perform well. Not sure of throttle size ? Check ebay for secondhand ones.
56astro ·
Electronic fuel injection system, fed by 46mm throttle bodies and ram air intake with large volume airbox
I think it still uses a plenum ("air box") as this gives the ECU the signals it needs to run efficiently/properly.
In any event - 4 x 46mm TBs :bounce
Glenn
Vintage has some IDA throttle bodies 50mm available
Thanks Dave, but I want to run IDF style as the manifolds are straighter and work better, IMO
56astro wrote:It has been said that this intake design is pretty close to ideal.
Is that yours, Astro?
Ahhh... maybe not. US tail lights.
Hope it isn't yours.... because I reckon that, from an engineering and drivability point of view, looks silly. Throttle response would be disgusting with such a large total plenum volume and distance from butterfly to port and it would be an absolute bitch to tune for transients at low throttle openings and and and.. I think I'll stick to IDF TBs thanks!
[Edited on 21-10-2004 by VWCOOL]
56astro ·
This is what an FI guru on STF wrote about this set-up:
Thats a very smartly designed plenum. Very nice solution. The mini plenums at each end of the center, though not fully conducive to velocity, are very conducive to taming knuckles of turbulence from turning the 90 degree. Nice compromise decision. It may actually be close to spot on depending on the engine size. Its really hard to tell from the photo. I would say its close to 2.0 liters. The 1.7 D-jet...which is excellntly sized, is right at 1 liter for the plenum and about 400 cc per runner...so the whole set up is right around 1.6+ liter.
lol... yeah, 'conducive' and 'knuckles of turbluence'... :blah Stuff that s*it! If they'd designed it properly, they wouldn't HAVE 'knuckles of turbulence!!! Thanks for the pic, Astro, but for a variety of reasons I have to say that is WAAY off a good design... it's a pile of parts!
56astro ·
I agree, that design is not conducive to good air flow from TB to valves.
Because of the design of the flat-4 any single TB induction system will be compromise.
I like the std VW twin port FI castings that CB sell, but not sure of the internal dia. If they made a similar one without 1-into-2 at the end, I think they would be real winner.
Designing a plenum for a straight 4-6 or V6-8 engine is going to be easy compared to one for a v-dub. But still, even the WRX STi still has a plenum system in preference to individual throttle bodies.
What's the engine going into?
The engine is a new one for my Beetle - Oval/IRS etc etc
pete wood ·
Hey guys,
I have an subaru EJ25 in my buggy.
At the mo I am thinking about how to get it ready for the drags.
It is the dohc motor, so the heads flow big standard so i am told. It puts out 165hp standard. I am looking for around 225hp.
before anyone suggests it, I am not interested in a turbo.
1. the car has to be street registered (keeping wife happy) and it can't be with a turbo with that much capacity.
2. I want to run all motor class and that means no turbo and no nitrous.
What i am trying to figure out is whether to go to quad throttle bodies (big $$$) or stay with the standard intake manifold. Guys in the states say it is very efficient, but surely 4 throttle bodies would be better? I know it would need a plenum, but I will figure that later.
Any thoughts?
nah, for WOT plenum and TBs don't matter. Plant 'n go! I'm looking for crisp, on-street and on-track throttle response
pete wood ·
VWCOOL wrote:nah, for WOT plenum and TBs don't matter. Plant 'n go! I'm looking for crisp, on-street and on-track throttle response
What's "WOT" ?
56astro ·
So how will the ECU know what the MAP is?
Or is it not important?
pete wood ·
WHATS "WOT"?
56astro ·
I think "waste of time"
lulu94 ·
ryan here on danielles nick,
just onto the quad TB vs. single, the quads will give more response as they will be near the ports etc.
and with any decent aftermarket ECU, the load input should be able to be set to work off throttle position rather than MAP.
they do this alot when injecting non turbo big ported rotors, as they have a very erratic vacuum signal at idle.
ratty 63 ·
WOT = Wide Open Throttle
Something that I noticed whilst doing the research for my EFI system (Delco/Kalmaker with JE Camira components) is that the factory VW EFI on the Type I engine does not use a Plenum chamber.
It is generally accepted that Plenum chambers are used to dampen pulses in the intake vacuum at low revs/idle. This helps to stabalise the MAP signal to the ECU. Some of the aftermarket ECU's can be told to ignore the MAP signal at certain revs, effectivly making a plenum chamber unnecessary.
I haven't used a plenum chamber on my system, so all I had to do was desensitise the acceleration and deceleration enrichment (triggered by changes in the vac signal) and all it all worked using a MAP sensor right down to an idle. I could have also made the ECU ignore the MAP signal at an idle, but the manufacturers of my ECU reckon that you almost need a V8 supercar spec cam to warrent doing this!
Of course, if you do decided to go with twin TB's, you will still have the issue of unbalanced linkages, just like you do with twin carbs....
Make sure that the TB's are not too big, as this can cause the engine to have a 'boggy' feel to it when you open the throttle. One of my friends is currently running a TB from a 4.0 litre Falcon on his Microtec injected 2 litre type III, and it suffers from this issue. He is just about to change the TB to one from a Hyundai or similar vehicle to see if this is the only cause of this problem...should know soon. Exactly how to define 'too big' is a tricky one though!
Connecting the IAC and MAP sensor on twin TB's is not a problem. The map sensor is connected by running a balance hose between the TB's and fitting the MAP sensor in the middle.
Of course, twin TB's look great! I would still attempt to fit a single air cleaner to the system though, as I have read plenty of times that this helps throttle response too....
....I just thought of something, when running twin TB's, could you run the balance hose from each of the TB's to a sealed box, then run the MAP sensor from that box. The box would act like a Plenum Chamber wouldn't it? Might help someone out if they are having problems where vac signal fluctuation is causing problems on a twin TB set-up....
Just make sure that you ECU can do everything that you are likely to need it to do - this will be your limitation....
R 🙂
pete wood ·
could you post a pic of your setup?
what ECU are you running?
pete wood ·
any ideas for a factory set of TBs I could adapt, or would I need to buy aftermarket jobbies?
ratty 63 ·
...yep, I'll have to go and take a decent pic first though! Anything in particular that you would like to see?
I'm running the Delco 808 ECU (from a JE Camira/VP Commodore/VN Commodore/N13 Astra/N13 Pulsar) that has had the Real Time board fitted by the guys at Injection Connection in Perth. Have a look at their Web site: http://www.kalmaker.com.au if you are interested in the ECU and software....
R 🙂
pete wood ·
BTW, how critical is the distance between the ports and the TB?
coz I was thinking, if you could bring the induction tubes across the top of the motor and put the TBs right next to each other, you might be able to solve the whole "linkage going out of adjustment so often" issue.
Didn't Lee Harris (dark green 58) have efi with quad TBs on his motor?
is he on the forum?
ratty 63 ·
the distance between the TB's and the ports is not all that important as far as I can tell (from the info that I have read). If you were going to go to the bother of mounting Twin TB's side by side, to eliminate the linkage problem, you may as well just use a bigger single TB.
Remember that size of the intake manifold is not a important on an EFI system as it is on a Carbed car as you are only drawing air through the manifold, not a fuel mix.
I have used a standard 1600 TP manifold center, with modified 1600 TP end castings (modified to hold the injectors), and an adaptor to allow me to bolt the TB on to the manifold center....perhaps not the ultimalte way of doing things, but it definatly works!
I have to go to work now.... I'll be back later!
R 🙂
pete wood ·
ratty 63 wrote:the distance between the TB's and the ports is not all that important as far as I can tell (from the info that I have read). If you were going to go to the bother of mounting Twin TB's side by side, to eliminate the linkage problem, you may as well just use a bigger single TB.
OK, but why do the 20valve 4AGE motors and numourous other nutso factory NA motors run quad TBs?
They have to be good for something?
does anyone know what porsche use on their crazy NA motors these days?
The distance between throttle plate and port is very important. Having a short distance between the throttle and the ports gives the best throttle response, especially with no plenum - that way, the atmosphere pressure can fill your cylinders as soon as the throttle is cracked open, not have to blow air through a long twisty messy labyrinth of pipes and chambers. Instant fill = instant throttle response and better power (less loss through intake system). That's why many higher-performance cars have multiple throttle bodies
MAP (manifold actual pressure) on my planned management system/Beetle will be sensed from a remote 'vacuum chamber' ported to each throttle body... I will possibly mount the IAC (idle air control) valve to this remote chamber, too. I have seen this doen before with success on 8TB V8s etc but there is teh risk of the IAC affecting the MAP if both are plumbed to the one chamber - they may have to be independent to help 'dampen' vacuum pulses. For thsi reason, I may possibly use TPS (throttle position sensing) for my idle control if the MAP method doesn't work... not sure yet....
lol... thanks for the link, but with terms like 'expandable air', I didn't bother reading past the first sentence... 😉
[Edited on 22-10-2004 by VWCOOL]
pete wood ·
VWCOOL wrote:The distance between throttle plate and port is very important. Having a short distance between the throttle and the ports gives the best throttle response, especially with no plenum - that way, the atmosphere pressure can fill your cylinders as soon as the throttle is cracked open, not have to blow air through a long twisty messy labyrinth of pipes and chambers. Instant fill = instant throttle response and better power (less loss through intake system). That's why many higher-performance cars have multiple throttle bodies
So I guess you'll be using the lower Type 3 style manifolds will you for shorter inlet tracts and better throttle response?
Leigh Harris' car had these issues with the 4 TB injection,
"Although visually pleasing to the eye it was no five-minute job to change spark plugs and the quad throttle bodies never stayed in sync for more than 100 km."
seems like he had some real linkage issues. 🙁
Apparently it was pretty loud too. 😎
No, if I got to EFI, I'll be running normal IDF style equal-length manifolds topped with IDF style TBs, drilled and tapped (probably) for idle function from a remote, single central IAC 'plenum'.It's all in the planning/investigation stages atm.. but I certainly won't be running some 5-foot long, dual-plenum intake system with more pipes than a public dunny!
Linkages are easy... but I'll have a chat to Leigh as well
This is the Kalmker forum, so there is a fair bit of chat (this forum is fairly slow moving, so if you post a question, be prepared to wait for an answer - most of the members are probably out driving/enjoying their cars! 😀 )
I will try to post some pics of my system later today....
R 🙂
ratty 63 ·
OK Folks (or should that be Volks? 😀),
I have taken some more pics, initially I thought that I would just post the pics here, however I felt that the lower resolution pics wouldn't really tell the story in enough detail, so I will post the links to the full size pics (in my personal web space) with a description of what you are looking at.
Firstly I should point out that the finishing touches have not yet been put on the system as I didn't want to make things too permenant until it is all installed on my 1835 engine, and the body is back on the car - so this is why the wiring loom is still unwrapped, and you can see the odd wire/connector left hanging (some of this is for the Air conditioning controls and condensor fan that are not yet fitted!)....anyway, here we go:
Engine - the entire engine as it stands at the moment. The Baja style exhaust makes it difficult to get good pics of the dissy and TB, but I did try!
Throttle Body - the Camira TB (which includes the Idle Air Control (IAC), remounted on a standard VW manifold centre. There are a stack of vac ports on the back of the TB (not visible in this pic) that had to be blocked off. The vac hose coming out the side of the TB, over the top of the altinator, goes to the MAP sensor, which will be mounted on the firewall when the body goes back on.
Throttle Body and Adaptor - much the same as the shot above, except that you can see the adaptor that I made to mount the TB on the VW manifold. Sure I could have mounted the TB directly onto the manifold if I had welded the flange for the TB onto the manifold (if it cleared the altinator), but this system was designed to be bolt on (as much as possible 🙂 ). Also, in the back of the adaptor is the IAT (Intake Air Temp) sensor, another good reason to use the adaptor.
Distributor, Coil and TB - The Camira Dissy can be machined to fit the VW case without too much trouble. The drive foot on the Camira Dissy fits the VW dissy drive in the case - so just machine and drop in! The bottom edge of the dissy comes very close to the old fuel pump mounting, but as I won't have this mounting in my 1835 case, it's not really an issue. The coil is from a Camira (easier to just bolt it on, rather than change the wiring). You can also see the bracket that I made to enable the throttle cable to connect to the TB.
Injector Mounting - I had the standard TP castings modified by a friend of mine who does alloy welding. They are not perfect (internally) so I am planning on changing them in the future. Although mounted in the best position for fuel delivery (in theory), the injectors are going to cause problems with clearance in relation to the bodywork so I will mount them in a more upright position, further up the end casting next time. I have used standard type III fuel rails and Camira injectors with the plastic clamp section removed from where the hose is fitted. Alternatly I could have used VL Commodore injectors, which are designed to fit like this anyway.
Fuel regulator and injector mountings - another shot of the injectors. You can see the injector mounting brackets (home made!) and the fuel regulator (Camira item). The fuel return line then runs back along the manifold to the surge tank.
Temp sensor - NBTurbo, this ones for you! This is the 'Temp Sensor II' from the Type III and Type IV factory EFI set-up. There was no fitting for this sensor in the heads fitted to this engine so I have just wedged it in place between the head and the tinwear to stop the ECU from throwing an error, however the heads on my 1835 do have the necessary fitting 🙂 . It is located on the 1 & 2 side of the engine, but it could have been put on the other side.
O2 sensor - This is a three wire heated oxygen sensor, original fittment in Ford Falcons. I welded a O2 sensor nut (available from good exhaust shops) into the neck of the collector, just below the three bolt flange. I also went to a wreckers and purchased a short length of wiring loom from a Falcon so that it could be made to just plug-in, making exhaust removal or sensor replacement very easy.
Surge tank (top) and low pressure fuel pump - top of my surge tank (currently held in place with a couple of chunks of wood and g-clamps :duh but will be bolted to the underneath of the parcel shelf once the body is back on). You can also see the low pressure pump, used to pump fuel from the main fuel tank to the surge tank.
Surge tank (bottom) and high pressure pump - the underneath of the surge tank, the take off hose that goes to the HP pump can clearly be seen in this pic. The HP pump is a Jap pump of unknown origion, but I have also used a pump from a VL and a pump from an EFI Kombi to the same effect.
ECU - the Delco 808 ECU, fitted with real-time board. The ECU will be fitted to the inside of the firewall once the body is back on. You can see the Data Cable plugged into the top of the ECU. This cable would normally go to the back (serial port) of my laptop so that I can tune it and see what the engine is doing. Fantastic just being able to change a number and hear it effect the engine!
Some of these pics, and many others can be found on my website if you would like to know what I went through. (click the "www" button on the bottom of this post to go to my website.)
Is there something that you would like to see, that I have missed?
Hope this helps to answer some questions! 😀
R 🙂
[Edited on 25-10-2004 by ratty 63]
ratty 63 ·
...of course I also had to have the fuel tank modified for a return line and fit the return line to the pan. I have also used the Camira wiring loom (needed very little modification once it was unwrapped and eash plug was identified), the relays and mountings from the Camira and even the fusable links from the Camira (mounted next to the battery). I had to add a couple of relays to control the Low Pressure pump and heated O2 sensor, but that relativly straight forward wiring!
Also, the fact that I used the Temp Sender II to talk to the ECU means that I can still use the VDO sender (mounted in my block) to operate the (oil) temp gauge on the dash. The Tacho can be wired straight into the loom as there is a take off wire already there! Too easy!
R 🙂
nbturbo ·
Still watching all the moves.
thanks for that, ratty. Sums everything up nicely! I have joined the Kalmaker forums
Now, about those IDF style throttle bodies that I want to use...
ratty 63 ·
...oh yeah, thats what this thread was about wasn't it....:duh
