Just a general question here people and I am embarrassed to be asking coz I just know it is probably obvious but...
With popouts for type 3 fastbacks, how does the window push out?? I understand about the inside clip, but how does the window give at the other end (the fat end)???
If someone has popouts on their fasty, a pic would be great.
Thanks,
Pat
Menangler ·
The glass just bends, freaky hey!
Paddo ·
Really? because my fasty has the clips not yet attached and so I thought maybe it had been only half installed, so the glass bends?? freaky.
Tazz ·
Yes... The glass flex's... The whole rubber has a inner metal frame, The Fat end you called it... has a metal outer frame... all inside the rubber.
So when you open the window... it holds together...
There is 4 small nuts that hold the rubber/frame...
They are located inside the window frame..
Just peel back the rubber and you will find them..
