14yroldwith1963beetle wrote:Might be a can of worms but what is the BEST oil for VW's
or what do u use (_W?)
adz
There is no "best" oil.
VW Owner's Manuals all say that you can choose any decent brand oil of the appropriate weight, and use it.
Up to about 74, VW specified single weight oils and you had to chnage the oil with the weather as well as every 3000 miles. Form about 75 they started recommending multigrades, which were then high enough quality to last (they came out a few years before that but were originally problematic).
So for most Aussie climates any decent 20w50 will do just fine. And in snow country, a 10w30 is a good choice.
A few years ago a woldwide poll was held on one of the VW newsgroups. By far the most popular oil was Castrol GTX (20w50), as it's a good quality oil, available everywhere, and not too pricey.
But other brands got a mention too - BP, Shell, Total, Pennzoil and so on.
Penrite HPR30 is a good choice in Aus too, and is recomended by some VW shops.
I've found that once an engine gets about 20,000 miles on it, Castrol XLA (25w60) works very well to reduce any oil burning as the engine ages.
Yes - that's 25w60, and before you jump on me, if you know anything about oils and centistokes (the measurement of viscosity), you'll know that the engine is still only coping with the cold-viscosity of a 25 oil (about 130 centistokes), and the hot-viscosity of the 60 number is still only 18-20 centistokes at 100c (a 50 oil is about 14-16 centistokes at 100c). If it can cope with 130 centistroke viscosity, it can certainly cope with 18-20!
My engines last a LONG time - In fact one of them I've had since new (1970) and it's still going.
Synthetics will work just fine for both lubrication and cooling, but they are expensive and you can't leave it in the sump any longer just because it's a synthetic - you still have to change it every 3000 miles to keep it clean.
