baja bus rear flairs
https://forums.aussieveedubbers.com/threads/30619/baja-bus-rear-flairs
handycam ·
baja bus rear flairs?? ive noticed alot have them. wat are thay off most of them have a good shape that maches the line of the car . or are thay made 4 the kombi ? if thay are custom kombi were do i get some ????:thumb
11CAB ·
Originally they were copied off a 40 series cruiser, but you can buy them from Volksconversions on the Gold Coast
handycam ·
hi graham finely got a bus 2 baja " ok so 40series?? do u know what the ones from the volksconversions are worth???are thay just 40 series or have thay been modiffied??
11CAB ·
The 40 series have one leg longer than the other.......
The Volksconversion ones are the correct length for the kombi
handycam ·
ok cool thanks
11CAB ·
You'll also need to modify the sliding door arm to clear the flares when you open the door. I think i lengthen mine by about 100mm, used a kombi tie rod to do it. And you need to move the stop the same distance back so the door swings into the body at the correct time.
sand kombi ·
Try volksengineering as his are made to the kombi shape,
if its for a van he may have the spacer for the door, to extend the swing so it doesn't hit the guard .
I have a picture some where, but it maybe to big
0408199639- 38417005
handycam ·
thanks 4 that no shore which way im going yet baja or not 2 baja ???????????
