Is it compatible onto a T1 generator? if so, how do I get the $%^! woodruff thingy loose?
*did* ·
woodruff? i dunno.
does it hold the inner half of the pulley on?
oval TOFU ·
yeh, its a semi circular thing that retains the pulley onto the generator axel..
The pulleys are different. Tap the key with punch & hammer at one end and it will pop up.
oval TOFU ·
So can I use the T3 on a T1 then? or won't it fit on the gennie axel? Just asking here before i take apart the pulley coz it's a mate's pulley! not mine!
[Edited on 3-11-2004 by oval TOFU]
oval TOFU ·
Check if the offset is the same, the shaft size and nut etc will be the same.
oval TOFU ·
cool.. the only thing is, there's no cut outs to jam a screw driver in so you can unbolt the nut!
