barls ·
sound proofing
https://forums.aussieveedubbers.com/threads/30740/sound-proofing
Gibbo ·
Would be best to do both I spose....
barls ·
57kombi ·
Dave
I have glued it inside the doors - behind the rear side panels,
I also covered the roof with the same blue foam about 15-20mm thick... I have some carpet underlay padding about 20mm thick to put under the carpets... I also used some pressure pack foam sound deadener every where I could...
[this stuff is used extensively in prestige cars--]
especially around the rear window etc -- anywhere that could stop the noise of the engine... I will also cover under the bonnet area with either carpet underlay or foam matting..
and maybe under the bonnet itself... I am trying to use as much sound deadening as I can without making the car any heavier... such as not using bitumen type products which are great but very heavy... You can buy specialized sound deadening products but they are costly.... I hope this helps.
Lee Noonan 68AutoBug
johny rotten ·
Its much better than having carpet underlay etc inside the doors where they can get soaking wet....
My car will be still around 30 years from now- I guarantee it..
and RUST FREE.... includes body and chassis.....
Lee - using fish oil since 1964 --
If You don't have anything to say - that makes sense ---
best to keep Your fingers off the keys...
jonno-t3 ·
first kind of tile
second kind of tile
jonno
[Edited on 29/10/04 by jonno-t3]
VWFOOL ·
barls ·
twoguns ·
barls ·
twoguns ·
barls ·
barls ·
Dasdubber ·
ColumBUS ·
The_Bronze. ·
I rin twon cannons out the rear of My baja and it is a loud car - some how the note at 100kph is quite pleasant though. I know when I'm at 100 (or 60) because I can hear conversation, the radio and the kids (unfortunately) in the back. I reckon with some better rear speakers I won't be able to hear the kids so there is room for improvement.
Bronze.
EDIT: I forgot to mention the three litres of black Tar inside (on) the pan, in the car and inside the wheel arches - this makes a huge difference. You will be surprised. The Tar actually cut more noise that all the inner underlay combined.
Bronze.
[Edited on 8-12-2004 by The_Bronze.]
besides off the bitumen road.......
That sound great... but it would cover over My nice blue killrust paint.... under the guards...
barls ·
mnsKmobi ·
almanoids? Is that Orminoid? I've used Orminoid. It's bitumenous paint that takes ages to dry/set and is still a bit soft even then, so be careful where you put it.barls wrote:just found out ill be using stone guard under the car and black jax or almanoids inside
barls ·
carisma ·
Many of these products are new to me.... and not readily available in the country....
its good to see You are getting good results...
cost cutting....
Freddie Fender ·
Go authentic and don't have a stereo!! I find the stereo interupts the music in my head!!!!
barls ·
RENNWAGEN ·
barls ·
barls ·
boof2332 ·
I just built 7 sound proof teaching studios for my mates music shop..he got this new stuff called WAVEBAR.
It looks like lino and can be cut the same..comes in 8kg per m2 or 4 kg m2. It absorbs the sound, not reflects it. The rooms we built are awesome thanks to one layer of this stuff inbetween each room. I have some for my car..you can cut it and use it in the floor or on the fire wall and it is only about 5mm thick.
Matt
oval TOFU ·
Just wondering...
barls ·
ruckus ·
oval TOFU ·
Yeh, I'm gonna be tootling along in my glorious 40HP! Every gram counts! I usually take a sh!t before I drive so the car goes faster!barls wrote:weight is no an problem for me with the t4 2L
boersch ·
hahaha, you could make a killing selling vw stickers with that lineI usually take a sh!t before I drive so the car goes faster!
barls ·
oval TOFU ·
I only keep it stock coz my wallet and my front drums tell me to do so!
barls ·
I have to have front disc brakes and a collapsable steering column...
I also like bumper bars....
& electric fuel pumps and electronic ignitions.....
& H4 Headlamps....
& two speed wipers.....
& Driving & Fog lamps....
& reversing lights....
barls ·
Grock ·
Try this site, seems to have some altenative product choices when it comes to sound deadening!
Dan
hallph ·
Also, which areas in a 75 Kombi would be the 'key' areas to sound deaden in order to reduce both road and engine noise? Front doors, floor, tire wells - what about around the engine bay?
KruizinKombi ·
Even with the engine noise taken care of, any large flat panels will add noise if not dampened in some way. A lot of the noise found in kombis is not engine noise anyway, just vibration caused by road surfaces, wind, etc. Try driving your kombi fully packed up for camping, and you will notice how much 'other' noise is around; you just usually can't hear it above the engine noise. The roof, inside side panels and doors, and even the floor would benefit from some sort of damping material. The bituminous stuff is reputed to be the best, but as others have said, it is heavy. Remember that the panels do not necessarily need to be completely covered with dampening material; a section in the middle will still dampen a lot of the vibration. (Have a look inside many factory-finished vehicles)
As RENNWAGEN already suggested, check this site out...
Heat, Rust, & Noise in VW's
barls ·
oval TOFU ·
How much did you get for how much $?
Did you you use a hairdryer to mold it or is it adhesive backed?
What's the mean rainfall in Kyrgyzstan for 1997?
barls ·
i think it was 24mm of rain that year. 🙂
oval TOFU ·
so hows it sound? or, not sound for that matter?
[Edited on 8/6/2005 by oval TOFU]
barls ·
penguin ·
has the engine come back yet????
mnsKmobi ·
Be warned though that the kombi in that article is supposed to be a real rust bucket now. Make sure that you treat any rust b4 covering an area with soundproofing. Also, don't use anything that can hold moisture - like insulation batts.KruizinKombi wrote:As RENNWAGEN already suggested, check this site out...
What I have been doing is coating areas with fish oil, rustproof primer then bitumenous paint. Takes a while but it shouldn't rust in a hurry! So far only the front doors and the front passenger's wheel arch have been finished and it is noticeably quieter at 100 kmh.
oval TOFU ·
I was thinking that there wasn't that much prep done when he mentions filling all the door cavities with sound deadening foam and other stuff like that...mnsKmobi wrote:Be warned though that the kombi in that article is supposed to be a real rust bucket now.
barls ·
oval TOFU ·
Was wondering if I should I tear out the old sound deadener if I'm replacing parts of it? nn[ Edited on 19-7-2005 by oval TOFU ]
barls ·
barls ·
then fitting the kick panels in place to mark where the speakers would sit and covering the back in the dynomat
heres them sitting in place
hallph ·
I've just bought myself a pack of 24 Bostik sound deadening sheets - i'll put them in my van sometime but i doubt they are flexible enough to place near the engine, possibly just in the doors etc on the flatter surfaces 🙂
barls ·
azz ·
hallph ·
I too would like to know what i can use in the engine bay to quiten it down a little for those who sit in the back seat - anyone have any products?azz wrote:What product can I use in the engine bay of a kombi?
azz ·
barls ·
ryfoz ·
The guys from this site 'Heat, Rust, & Noise in VW's ' said he steam cleaned the interior metal surfaces of his bus.........
Does this sound like a bad start to anybody else?
I would have thought HP air and a decent Solvent based cleaner would probably be the best start to clean out the shit and prevent any cleaning moisture entering any cavities prior to treatment.
barls ·
azz ·
barls ·
Learner ·
barls ·
rearengine ·
one is approx 12mm thick and the other is 7mm thick
the thin one is $5 a roll at BIGW and Go Lo etc..
I used all around My engine bay - inside and outside
glued it on with contact cement..
cover both the foam and the metal with contact then let it go tacky dry... then put them together..
they will never come off... if You only use contact cement on one side.. You can pull it off...
I put two layers of the 7mm stuff on the roof...
behind the back seat - on the sides - in the doors...
its virtually water prrof... I also have it under My guards to stop stone chips... lol
around the engine bay plus under the engine bay I painted it all matt black...
that was 12 months ago...
I recommend it.. its cheap - waterproof - weighs nothing..
and sound can't really go thru it....
barls ·
it also has taken out some of the road noise
of foam in My engine bay,,,
barls ·
