Thanks for all the recent advice on replacing my handbrake cables......performed the task today, had a few areas requiring much swearing, but I now have a handbrake again and am happy. Thanks to all!
But......two questions....
- the cable in the drum......the end attaches over the lever in the drum, then runs through a 'claw' and exits out through a hole ('69 bug)....the only way I could get this to happen was to bend the claw out, and back again....is there another way to get the cable through here? Made a bit of a mess doing it and it was hard to do.
- Put in 2 new cables (only one had broken), one tightened more than the other, even though I have them set the same pressure on the brake, etc...is this a problem? I know I need to check the adjustment for a while after putting in new cables...will this eventually work itself out?
Thanks again to all for the advice....
phantom ·
