i put a kit on another car years ago & it worked well (no more checking the points).
does anyone run these, what are they like & what are the options?
thanks
hs400
helterskelter400 ·
https://forums.aussieveedubbers.com/threads/309/electronic-points-kits
helterskelter400 ·
jakriz ·
Grey 57 ·
helterskelter400 ·
aussiebug ·
Grey 57 ·
70AutoStik ·
aussiebug ·
I'm Rob rather than Bob please :-)Grey 57 wrote:Hi Bob
Thanks for the info on the Compufire.
Didn't know about the No3 cylinder thing. I am using with internal cooler and 009 dizzy. Have set the timing at idle at 7.5 deg BTC (1600 SP) . Will slightly retarding ignition get around the No 3 heating / pinging problem? Got to say that since fitting the unit I have not had any heating or pinging probs.
Baja Wes ·
Grey 57 ·
Grey 57 ·
70AutoStik ·
aussiebug ·
No problem - I've got 10 thumbs too :-)Grey 57 wrote:Thanks Rob, sorry about the typo on your name mate. All thumbs when it comes to typing.
PULP and LRP have the same octane ratinig - 95 (or 96 just for Shell petrol). For VWs with normal compression ratios (up to 7.5:1) you should be able to use normal unleaded (91 octane) and have no detonation. LRP is more likely to cause rough running and plug fouling that either unleaded or pulp.I'll check my 009 like you've suggested to see if it has retard on 3. I have been using PULP in it but it seems to run poorly compared to Lead replacement petrol. Must be the octane rating.
If you know which mark is TDC, then make a new mark 46.5mm around the rim to the right of TDC. That mark is 30 degrees BTDC and you can work 3mm either side of that for 28-32.If you have no degree pulley how do you recomend setting advance at 28 to 30 deg. Is there a measurement you can use from the existing timing marks?
Dean
aussiebug ·
70AutoStik wrote:Aussie, the vacuum advance only provides extra advance when it senses the cylinders are only being partially filled - therefore the effective compression ratio (pressure at TDC) is less. This advanced timing brings the peak flame rate back to where it is most useful. The 009 doesn't have this and does produce more advance in about the 2000-3000rpm range at full throttle than a stock dizzy.
BTW, where does Ben Durie hail from - or aren't we allowed to ask that?
70AutoStik ·
Grey 57 ·
aussiebug ·
Eh - not that I've ever seen, and I've been driving VWs since 1967. All beetle pulleys (and that includes type1 engines in Bus/Kombis) are the same.Ben Durie wrote:hi,
hey rob that 46.? mm can not be correct for ther are several different diameter pulleys as O.E.
regards
Ben
aussiebug ·
You're right Grey - the 009 is a 'one size fits all" distributor so it is NOT ideal for any particular application. The original centrifugal carby was designed for the very early bus engines - 1200 engine pushing a very heavy body, so the 009 style worked OK since the engine was ALWAYS working hard.Grey 57 wrote:From all of this, it sounds like the 009 dizzy's are not all there cracked up to be. What is the best vac advance dizzy to use on a 1600, in a beetle, to get good power, no flat spot, with a standard carb?
Baja Wes ·
aussiebug ·
Thanks for the info on pulleys guys - I'll have to take a tape measure to the next VW meeting I go to :-)Baja Wes wrote:I can also verify there are different diameter crank pulleys.
The vacuum advance will help increase fuel economy slightly over the 009, but I still prefer the 009. With the vac and the 009 set to the same total advance the vac distributor caused more knocking problems on my old 1835.
