externel oil cooler's
https://forums.aussieveedubbers.com/threads/30906/externel-oil-coolers
kombi_kid ·
hey guys
what sort of externel oil cooler best suits a kombi and where should it be located?????? pics would be great if possible!
rhys
kombi_kid ·
so no one has one in there kombi's??? common guys!
rhys
kombikim ·
I have & I found the thread in tech but the pohotos are gone
mine sits flat about 1/way up vehicle between heater tube & closest longitudinal "chassis" , it works so well that it has been wrapped in light sheet aluminium since about April to keep oil warm enough, unwrapping again soon though
BiX ·
I found i had to put a alum plate over min in winter and wrap the lines in themo wrap to keep them warm, as it ran really cold.
nbturbo ·
sounds like you need one of these to keep your oil temp up
nbturbo ·
or one of these if you have a Type4-a bit neater fitting
kombikim ·
yep, I need a thermostat of some sort, have a remote filter, that is underneath battery floor
kombi_kid ·
so what sort of oil cooler did u use???? did u use a separate oil filter???? you obviously didnt need to run a thermo fan?
rhys
Chewy ·
For the oil cooler I'd say get something like an auto transmission cooler from any late model car from the wreckers. Would be a hell of a lot cheaper than buying new.
kombikim wrote:yep, I need a thermostat of some sort, have a remote filter, that is underneath battery floor
That's what the pressure relief valve is for in the oil circuit.
kombi_kid ·
yer thatnks chewy everyone using 1/2" lines???
rhys
kombikim ·
yep
kombi_kid ·
kim can u draw a diagram of how it all plumbs up etc just so i get an idea of where it comes in and where it leaves for the cooler?
rhys
