is there a certain code on kombi motors 2 tell wat thay are (eg 1600 1700 and so on ) want 2 make shore my engine is 2 l ??? dont know much about kombis now i own one time 2 learn
[Edited on 1-11-2004 by handycam]
handycam ·
bump
barls ·
there is only one real sure way to check and thats disassemble the motor and measure the pistons
Warrenm ·
Usually 1800 engine nos start with AP
1975 2000 CJ or GD
1976 2000 GE
1977 2000 GE
Hydraulic tappet models start at GE 00007 083
Warren
handycam ·
barls i thort that .but just wasnt shore mine starts with . DC ????
11CAB ·
Never seen a DC number before....is that on the Fan housing or the crankcase?
If you look at the Crankcase just in front...or behind...depends which way you look at it....but anyway, between the oil breather and the fan housing will be the engine number as well, see if this matches the number you got
handycam ·
have had a look the number look wright but is dark and think its CA not dca just CA??????? the number is nere the coil sort off ????
11CAB ·
OK, CA means 1700, the number near the coil is the Fan Housing number...like I said there are 2 numbers....check the one on the case like I mentioned
handycam ·
ther are 2 numbers one on the tin were above coil and one on case bside coil CA046427 so its a 1700 ???
[Edited on 2-11-2004 by handycam]
11CAB ·
Are they both the same number?
handycam ·
cant realy read one have 2 have a look 2 morrow in the light ???
11CAB ·
These are pics from an upright conversion, but shows you where the 2nd number is.
11CAB ·
You can see the number is across from the distributor. and it must be stamped on the case, not the tinware.
handycam ·
found it CA038545 greas covering it ??
11CAB ·
Yup, looks like you got a 1700.....which makes sense since you have a 73 kombi.......sorry dude
handycam ·
:cry o well it still goes quite well so must be origanal donk ???? thort it was 2 good 2 be trew . thanks mate sorry 2 come a cross a bit dumb LOL
11CAB ·
1800 Piston & barrels should bolt right in tho....:thumb
handycam ·
LOL fu#$ it il go price a 2lt 2 morrow . not shore if il jack it up now " il fit it out in side and stuff an go from ther
