To get a professionally built performance motor, how long would you be expected to wait for the build, if you supplied most of the parts.
Just wondering.
seagull ·
Most guys will not assemble a motor for you using your parts .This is due to the guy not making a $ from just labour .
good guys do it in a day easy
Che Castro ·
Depends who it is, but some guys might use stuff like your crank and rods if they are ok. Still i'd bet at least a few weeks minimum. More time in waiting around for parts, waiting for machining, running around picking up things etc.
BiX ·
took my engine 4 weeks. but i dropped off a semi stripped engine, and it was dis assembled, cleaned, machining and balancing done of everything, rebushing of rods, machinng and polishing heads, full flowing the case etc etc,
HotRodMatt ·
Depends how busy they are and how much of a priority you have managed to convince them the job is!
If they do the machining "in-house" it shouldn't be too long - but you still have an outside dynamic balancer to contend with!
BiX ·
also i told my engine builder I would prefer him to have it done perfectly in 5 weeks rahter than a rush job in 3 etc.
theverybigtallman ·
professional + performance = 2 or 3 weeks at least. like is already said, how busy is the shop?
sax ·
1 day.
2 if he sends it away for balancing.
Seriously, he does it this quick and the results are pure joy to drive. Of course, he replaces anything stuffed with new and you pay all the way but you do get what you pay for.
sax ·
And that's in South western Sydnee.
barls ·
i just did one in 2 days with my old man
mountainbug ·
spose my problem was that i said i wasn't in a hurry
(bad mistake), that was around 4 months ago, hopefully will pick it up next couple of weeks.
barls ·
never ever tell a mechanic no hurry i did that 5 years ago and im still waiting
sax ·
Never tell a musical instrument repairer that, they charge extra because they find more wrong!
In reading your question "How long would I expect an engine rebuild to take?"
I would expect that it would take 2-4 weeks. When you say supply most of the parts, there is often some other small items that will be required.
If it takes any longer than that, there should be a reason.
