Fitting 914 Rims
https://forums.aussieveedubbers.com/threads/31221/fitting-914-rims
ruckus ·
Just wondering if I have to make any modifications to the ends of the axles to get the 914s to fit my standard '71 beetle. Had a look on the weekend and forgot how much the hub-caps dome to cover the ends of the axles.
ruckus ·
anyone?
Is it a common problem fitting non-standard rims?
Che Castro ·
The stock discs require a bit of machining to the lip where the bearing cap goes to fit porsche 5 stud alloys like phone dials.
Alloy rims have a deeper section than pressed steel wheels, there shouldnt be any problem clearing the actual axle.
ruckus ·
Ah ok. These are 4 stud so I shouldn't have any problems at all then?
AdrianH ·
No problems, I have them on an IRS pan with the caps on and they fit perfectly. Did you get the longer bolts with them ? The standard VW ones are too short.
ruckus ·
How hard is it to find the bolts? - just in case I don't get them with the rims
(they're still in another bloody state:cry)
barls ·
most tire places have them and micks has the stud conversion kits as well
