Ceramic fuse replacement
https://forums.aussieveedubbers.com/threads/31349/ceramic-fuse-replacement
voltz ·
is there any adaptor fitting to change the fuses from those crappy ceramic type to the blade type fuses ?
Yep - its is called time, effort and money.
Sorry Voltz, the only way is to get the pliers and wires out and find a donor fuse box from some where and start wiring.
Guess if you made the box up and then soldered the extension wires onto the tabs, it wouldnt be THAT hard
mnsKmobi ·
No offence but anything other than making sure you've got the right amp fuses in the right holes and brightening up the contacts with a bit of fine sandpaper is probably a low priority...
voltz ·
found a pre made fuse box from auto electrician today, holds 6 blade type fuses,Im going to use that, should be nice and easy
