Just wondering what everyone with buggies have used for sunvisors? For rego i got a pair of charade visors and cut them up to fit, they are a bit dodgy and would like to get something smaller that will fit better. Any suggestions? Can't seem to find any decent sized ones in the wrecking yards.
Thanks, Andrew
MickH ·
I use sunglasses.....:thumb
VDU.88A ·
would have to agree usually sunglasses
polaroid sunnies for the dunes
VDUBXTC ·
I use sunnies and a roll bar.
Never had any issues with not having any for rego
ancientbugger ·
Do not try a hat as it ends up very expensive! I've lost loads in the years I've had my bug .
ratbug ·
Hmm ok, i rolled up to the engineers without them not knowing that i needed them, but he said i had to put them in I took them out again after a while, they looked very dodgy, but i gotta take the car to the engineer soon to get the new engine done so would like a better attempt at some visors instead of the cut up charade ones.
VDUBXTC ·
Maybe think about going to another engineer.
there is a guy at cardiff that is good.
He has done most of the buggies in newcastle.
ratbug ·
Yeah he is my engineer.. He is good, but just picked on my lack of sunvisors. I might try some mini ones, they should be small.
pete wood ·
I had a thought,
why not make some up out of dark tinted or black perspex or lexan. use the mounts off your old ones. then you could make them the shape you wanted. i reckon it might look really trick. 😎
[Edited on 13-11-2004 by pete wood]
VDUBXTC ·
I am lost then.
Maybe what pete suggests😉
Mad Manx ·
???don't sunvisors have to be padded? maybe trim some from a bit of thin ply then cover them like yu would a door card- with that thin foam underneath. the vw fittings should be able to screw on.
ratbug ·
Yeah they have to be padded. The lexen and plywood, or even fibreglass could be the go, and then get them padded. Rung up a guy wrecking mini's but he said he throws out all the visors because nobody wants them.
