This 1960 panelvan is very straight and almost totally rust free.
It was hit slightly in the front right headlight and a little roughly repaired. No other damage.
It has slight bubbling at bottom of front apron ,but rear panel of front apron is good.
The cargo door sill has surface rust on outer section ,but inner panel is good.
The cargo floor and rear deck are excellent,with only 1 small hole near door.
Cargo area is covered in oil,cos ive used this bus to store old engines and gearboxes.
The steel cab divider section has been removed and 2 small sections of the rear firewall panel are roughly cut out,probably for a buggy exhaust.?
The engine door is a later one and the semaphores are missing as well as the rear lights.
It has Mercedes (?) seats fitted to the front cab and it has no engine.
The gutters and side panels are pretty straight and rust free and the under side looks great with only some minor surface rust. Jack points and outriggers and chassis rails look perfect.
The roof is good tho has some dents.
The cab floor is excellent and the dog legs look perfect as are the cab doors.
The dash and tray are good and uncut,tho has a small ripple in front of the ashtray which happened while rolling this bus off the trailer(only minor to sort out)
Cargo doors and rear guard’s are great original with only some slight surface rust.
Ive had it stored for about 15 years now.
It will be sad to see it go but i have no time to restore it .
Im asking $4000ono for this bus.
Bus is located in Perth
I have many pics of this bus,so email me if you are keen.
Email..choppaxs@hotmail.com
choppa ·
