I am curious to know if anyone has maxed out the negative camber on the front of a pre ball-joint beetle? I am curious to know how much can be achieved by moving the camber spaces.
I have done a quick search of the forums but haven't come up with many answers.
I know that its not possible too reach any serious negative camber however I am still curious to know.
Matt.
about 1 1/2 deg neg (max of 2 deg), after that you will get link pin binding.
pete wood ·
how do you do that?
silver ·
with the shims in the link pin assembly.
No the shims DONT adjust the camber
you have to actually bend the arms in a press and then you wont be able to make the thing work as if wont travel trhough its arc and will bind up
The shims are there to align the top and bottom arms and make them swing or travel through the suspensions arc without binding
Better off converting to a Ball joint front end if you want to get negative camber and once again bend the trailng arms in a press,
