Just got some flat 4 eyebrows and i can't seem to get the bastards to stay in place. They just want to pop out.
I'm trying to fit them to the '71 beetle.
Thanks for any help
ruckus 路
Problem solved thanks to Dean at Volkspower. Had to swallow my pride first though 馃檨
handycam 路
wat was the problem ??? 4 me in the futer
winerot 路
i have some for my kombi too
but they have the same problem
as yours, what did you do please
wally
vw54 路
there made for early headlights pre 67 and if you fit them to the round later type they headlight brows require a little gentle bending to get them reformed to suit the round frame.
kustomkool 路
yeh and a bit of man handling getting em in.
Midlife crisis 路
When I put them in my 72 fastie had to bend them but only enough so they are a tight fit.
Marc
vw54 路
Gentle is the work there soft n bend out of shape easy
ruckus 路
Hmmm was a bit more than that. Had to grind down the bottom corners a teensy bit so that they'd stay in. The distance between the ridge they're supposed to sit on and the curved edge around the front was too narrow for the crome mounting. look pretty cool now though.
ruckus 路
here we go. corry about the bad pic and rusty bumper:
[/img]
kroozzn63 路
pliers and a rag squeeze the hell out of the lower bits and pull the rest out from the edge it takes patience a pair of pliers side cutters for the bits where the light adjusts a firm hand and eventually they fit nice and snug
winerot 路
thanks i will bend slowly till it fits
light rings to be powdercoated black
should look good
