beetle engines & tinware
https://forums.aussieveedubbers.com/threads/31716/beetle-engines-tinware
blutopless2 ·
is the physical size (external) of a 1200 the same as a 1600 and therefore the tinware the same?
Brad ·
nope
Gibbo ·
1600 is bigger, and if I am correct you will have to snip out some tin around the engine bay in an early bug to get a 1600 to fit.
blutopless2 ·
will the tinware for the 1600 fit in the engine bay for the 1200? or are the engine bays different in sizing?
jnr356 ·
it is the same size around the outside,
a little bit tighter putting in the engine around the heater boxes
pod ·
i put a 1300 in mine easily enough just changed tinware and exhaust was originally a 1200🙂
mines a 61
[Edited on 18-11-04 by pod]
The 1500s 1600 and I think 1300TPs are wider - the engines bays in later models are a bit longer (I think) and wider. Need to do a snip of the tinware to get a later engine into a Oval, for instance... and the sealing rubber is still a TIGHT fit... might even have tin rubbin on body. Mine does...
