Squareback Headlight screw needed still....
https://forums.aussieveedubbers.com/threads/31740/squareback-headlight-screw-needed-still
Gibbo ·
I dont surpose some good samaritan would like to send me a couple of headlight screws? The ones that hold the headlight in at the bottom of the ring on a late bug or T3?
My Square is a 69.
I seem to be missing some on the squareback.
Will happily cover the postage.
Cheers.
[ Edited on 26-11-2005 by Gibbo ]
jonno-t3 ·
tel ya what mate....i think i got 4....and i really only need 2...if i can find the other 2...i'll send them to ya
give us a bit,
jonno
Gibbo ·
THANKS FELLA!
The FORUM works ... mutual interests working at a great speed.
jonno-t3 ·
sorry mate, only got one...will send u that if ya want? better than nothing
jonno
Gibbo ·
You have U2U. Cheers
Gibbo ·
Guys, The screw I was very kindly sent is the wrong one.
I still have a loose headlight.
Anyone else got a spare screw they can send? (at my cost of course)
Cheers!
PurpleT3 ·
I just used screws from Bunnings.
Dannyboy ·
Gibbo i'll have a dig around for you today.
Dan:thumb
Gibbo ·
Thanks mate, legend!
karmen ·
got a pic or measurements Gib as i hve a lot of screws also some benz stuff may match perfectly.
bernie
Gibbo ·
I'll sort something out tonight mate, many thanks.
karmen ·
u got
send me a pic
bfree
type_one ·
Mate if it the ones that hold the headlight to the car I am sure i have a few. Take a measurement and I will send you two.
Midlife crisis ·
If you have one (or even a shorter one) take it to a nuts and bolts shop and they will be able to match them. I have taken heaps of bolts etc into them and always walked out with exactly what I need for the fastie and the baja.
Gibbo ·
Three years on and I still havent found one... anyone? 🙂
they should be the same as on a beetle headlamp
1968-76 as chromed ring is the same..
they are a special screw.. c/sunk head [phillips]
stainless steel 5mm metric fine thread
measured end to end is 51mm long
on the early beetles 1968>
the screw was held in the chrome ring by a metal sleeve
later ones were loose...
the type 3 screws should be the same... IMHO
they have a phillips head countersunk [stainless steel]
and are 5mm OD x 51mm long end to end
there is a locating bit on the end to find the threaded hole
sorry, I couldn't post a pic camera is acting up...?
I'm just replacing one of My headlamps...
http://community.webshots.com/user/vw68autobuug
Finally had a photo come out
having major camera problems
or maybe computer problems [Me??]
Midlife crisis ·
i will have a look today andf see if i have any left under the house
marc
Special Air Service ·
Are they countersunk or button headed?
Might have some.
Brendan
they are countersunk headed screws
they sit into the chromed headlamp rim hole
which is fairly large..
very similar to tail lamp screws only much larger..
robnjo ·
does it look like this ?? and if so will 1 do you as I can't find the oter one.
...sorry its fuzzy, I've bin drinkin🤪
