Go to
http://www.aircooledtechnology.com
A 911 shroud even with a 5 blade and a small pulley will overcool pretty much any Type 4 under 2.4 L, unless it is running high compression or working really hard all the time. not to mention also costing a small fortune.
overcooling is worse than overheating sometimes as the engine can't heat up to proper operating temp, clearances stay too large, oil won't get hot enough to clean all the crap in it etc.
make sure u get a genuine 911 alternator, not a watercooled VW one. The 911 alternator has the proper thrust bearing inside it. Other alternators are just designed to handle the load of a fanbelt, rather than the thrust of a 911 fan at 5000rpm.
