correct oil level to be at
https://forums.aussieveedubbers.com/threads/32215/correct-oil-level-to-be-at
wizardroadster ·
Hi, I put some oil in my 1500 engine as it was just right on the add oil level mark, now I think i have put too much in as its right up the last mark on the dipstick which I think is the full mark. In the idiots guide to VW's it says dont put too much in or it will blow the crankcase or something?
Should I let some out?
if you have too much oil it will push past the oil seals and leak ...
so drain it and re fill with 2.5 litres no more no less
wizardroadster ·
so if its right up the last mark on the dipstick its has too much oil right?
oval TOFU ·
if its 2-3mm above the top line (max line) it'll still be ok
