hey fellas
there seems to be alot of non VW engined VW's kicking around at the present time so if u have one post some pics and abit of details!
rhys
seagull ·
This out with the vw twin port 1641 and I fitted a 2ltr Ej subaru quad cam .
Its a three wheel trike bike that I have made
I made my own adapter plate and drive hub and 50mm headers .
:beer
seagull
kombi_kid ·
that is phat cant wait to see it finsihed!!
rhys
twoguns ·
jeeezas... wouldnt that thing be always on the rear wheels. you would never be able to turn.:P
i have riddena few of johans trikes here on the central coast and it was always fun dragging the cage.
I had no idea where to even start If I had to post just one photo.
subawee ·
Hi Guys,
I've been lurking around this page for a long time. What a great site! I could'nt resist posting a few pics of my conversion. I started the project last october and last month I took my first trip with the new motor. We went to the Newfoundland mountains in the west desert of Utah. I could'nt be more pleased with the subaru motor!! I'd like to thank Peter W. for all of his help and for his web page. Wes I really liked your page as well. The first pic is of the conversion is about 3/4 of the way through. The second is of the first trip out and I think it sums up how fun the subaru is.
Thanks to all for all the help,
Bob
[Edited on 30-11-2004 by subawee]
subawee ·
wacked1 ·
wow thats awsome subawee
Baja Wes ·
I'm sure most people have seen mine. There is plenty of info and pics on my website.
[Edited on 2-12-2004 by Baja Wes]
VWFREAK ·
You guys are nuts, love it. what sort of hp are you getting with the conversions.
pete wood ·
here are some pics. the first one just before Zak was regoed and the last one as he is now with an air scoop for the high rear mount radiator.
Power output is 119kw at the flywheel. Not as much as wes, but still real nice 😎
pete wood ·
now...with scoop and radiator box
reub ·
Haven't posted for ages.....here's just a few pics.
Will post some more in a month or so.
boof2332 ·
Looks awesome......
There is obviously alot of work chopping the roof...how much did you take out and where exactly do you take it from?
Matt
pete wood ·
Hey Reub;
love the go-cart setup with just the cage and pan.
you should drive like that, that nasty steel body will add far too much weight :P
junkyardoval ·
Reub that is great. I knew you wern't just setting around. I can't wait for you to get it back on the road. It will be wild. If mine is half as nice as your I will be pleased.
Ernie
ratbug ·
I Got the EJ20 started tonight! I took some pics, and dumped them in my webpage folder (havn't updated the webpage yet). Link is HERE Its booked in at the engineer next thursday.
subaruboxer ·
Hi there,
I am installing a Subaru EJ22 into my `65 Bug. It has a `68 IRS pan, Porsche brakes front and rear. Here a picture of the engine with the trans and one of the engine.
nn[ Edited on 9-7-2005 by subaruboxer ]
subaruboxer ·
no.2
[Edited on 22-5-2005 by subaruboxer]
vwtyp2 ·
here's the 3.8 litre v6 in my bay.
ran a 16.2 at A.I.R. at 78 mph with stock induction and stock exhaust and a grabbing clutch, so I couldn't launch with any rpm, cos I had to hold my foot on the brake instead of the gas.
a few little bits, and it'll be in the 15's.
[Edited on 8-1-2005 by vwtyp2]
72FASTY ·
Any pics of any T3 conversions, esp with EJ22??????
Jenny ·
My project is a Eureka kit car based on a '68 T1 semi-auto pan. Motor is EJ20 n/a.
This pic taken with the lower rear panel removed. Lots of work left to do.
Jenny ·
My inlet manifold was too close to the rear fire wall to fit the rubber tubing. I could not extend the firewall back due to the bracket for the fuel tank and i could not use the 90 degree vertical elbow because of the low engine cover height (raising that would block what little view I had out the rear window and ruin the nice profile of the rear deck).
My solution was to cut the end off the inlet and weld on a tightly mitred 90 degree bend.
wacked1 ·
Hi guys this is my conversion. It's getting a 5L V8, the transaxle is a Porsche 915 5 speed, the trans conversion was simple, all i had to do was fabricate some mounts, and after many hours of research found that late model transport CV's have the same PCD as Porsche drive flanges and were able to fit the kombi half shafts with no modification, every VW shop had no idea either did Porsche shops finally a CV specialist in lidcome sorted it out, he didn't want to make the shafts so we sorted through a lot of CV's to see which would fit. clutch is sorted all i have to do is set up the shifter and the box install is complete. Also am setting up a full autometer dash and putting in bucket seats in the rear with harnesses. Will keep you posted i want it running for the CBB dyno day
wacked1 ·
wacked1 ·
fozee ·
Nice to see another V8 conversion in progress.
What is the longitudinal dimension of the 5 litre?
Will it fit with the original kombi engine lid closed? Is it alright for height and width also?
What is the diameter of the copper piping you are using for the coolant lines?
Good work! Hope to see it at the CBB Dyno Day!!
wacked1 ·
hey fozee my bus is in the middle of a heart transplant it used to have a leyland 4.4L v8.
look. will measure pipework later. my old v8 used to fit under the engine lid fine thats because my bus has been stretched 6 inches.
wacked1
subaruboxer ·
Jenny wrote:My project is a Eureka kit car based on a '68 T1 semi-auto pan. Motor is EJ20 n/a.
Hi Jenny,
looks great!!! What kind of header do you have installed, is it a selfmade 4 in 1 or 4 in 2 ??
boof2332 ·
Hey Jenny,
What model eureka is yours...I dont fit in them..
I would however like to put an ej20t in one of these...
Sorry guys..the pic is too big, it was a VW sp2.
Matt
[Edited on 26-2-2005 by boof2332]
Jenny ·
subaruboxer,
headers came with the ECU and other bits had to get (missing from the Eureka when I bought it) They are 4 - 2 - 1 but I'd like 4 - 2's so I can have duel exhausts
Matt,
The model is a bit of a contentious issue. I was told it's an F4 but have since found brochures indicating it is the last model XCL. Not much headroom, but more than a GT40 😉
Brad ·
pete wood ·
cool, that's gonna be a complete donut machine :thumb
Doug Sweetman ·
It looks sad with its droopy headlights.....
Reckon you have enough rubber on the back !! it'll pull wheelies if it has a decent clutch.
Brad ·
Doug Sweetman wrote:It looks sad with its droopy headlights.....
Not sad just checking outs it's new custom alloy radiator .....:party
Doug Sweetman ·
Noice.
If I ever win lotto Brad, my L bug is going on a truck straight to your workshop for an eJ20T.
Good stuff.
boof2332 ·
Those lights WILL be pointing foward when the front wheels are a foot off the ground.
Looks real nice.......I have always liked the buggy.
Matt
subaruboxer ·
Changed the intake and have a bigger airfilter now.
71superbug ·
what motor is that subaruboxer? looks like it was made to fit..
Anthony
reub ·
speedster356 ·
Here's Dave Birchalls (VW54) conversion.
subaruboxer ·
71superbug wrote:what motor is that subaruboxer? looks like it was made to fit..
