T3 extractor question
https://forums.aussieveedubbers.com/threads/32375/t3-extractor-question
Dannyboy ·
Have a question on t3 extractors. Once bolted to the motor and in the car how far does the extractor flange sit from the rear apron ( valance).
I'm getting a custom muffler made up and need a rough measurement.
cheers Dan
DallanMulley ·
Just gone and measured my 62 the flange is 30 mm but the silencer pipe comes out lower than the apron.
Dannyboy ·
What car have you measured it from and roughly how much lower is it. Could you run a Stinger or would you need a cut out in the apron?
Cheers , thanks for being bothered!
Dan😉
frenzix ·
on the 69square, my stinger fits fine.. clears the apron...
frenzix ·
as long as you get a type3 stinger..
Dannyboy ·
T3 stinger , Frenzix are you pulling my pud? Never heard or seen one.
Dan😉
frenzix ·
teehee
frenzix ·
any 3 bolt should do
Dannyboy ·
LOL , bloody knew it!
Dan😉
shiftyvw ·
If your planning on using a stinger im assuming this is a hot motor. Where are you getting big headers from. I had to build my own 1 7/8 system when I put the 2.3 with IDA's in the squareback.
Dannyboy ·
shiftyvw wrote:If your planning on using a stinger im assuming this is a hot motor. Where are you getting big headers from. I had to build my own 1 7/8 system when I put the 2.3 with IDA's in the squareback.
LOL i wish!!! It's only a 1776 with 44's , nowt fancy . The headers are only 1 5/8 which will be okay for now i reckon.
Dan😉
