Easiest way I've seen of late is to use a GPS. Most GPSs have a current speed reading. Just compare that to you speedo.
Gibbo ·
Erm, I mean that they actually work, not the acuracy.
Do you mean some kinda techy GPS system fitted to a car?
VWFREAK ·
I've used my work police radar gun before, but that only works when fitted to the car. I've heard of drills being used, but I'm unsure of the maths behind it. Works in theory I suppose.
MikeM ·
Gibbo wrote:Do you mean some kinda techy GPS system fitted to a car?
No, just a cheap hand held one in the car with you will do.
Even devices like the "road angel" that use GPS technology have a current speed readout.
as for testing if they work out of the car, yeah spin the shaft and the needle should move 🙂
Gibbo ·
Thanks all.
Yogie ·
Lionel Otto instruments in Evans Road Salisbury test them. Not sure how much it costs but we just had 2 beetle speedos rebuilt and had one of them converted to kmh for $160 if that helps. ( We got the kmh face plate from an L bug to fit on to the older speedo and he recalibrated it)
Yogie
Gibbo ·
Excellent info, thats just around the corner from me.
Cheers!
Gibbo ·
A very kind person just U2U'd me this info, thanks!
Hi when I tested my speedo I had a small nylon tool used for adjusting t.v's , filed down the end to fit in where the cable goes and used a drill ( running backwards from memory), to turn it. and if it sqeals the internal gears need lubrication.
If you just want to see them spin the needle get a battery drill n old cable hook them up and spin the drill in reverse.... easy
blutopless2 ·
should be able to test the accuracy with the drill also.. if you know how fast the drill is running then you can calculate the reading on the speedo.. should have the conversion on the speedo - usually stamped on the back.
jonno-t3 ·
yeh...as vw54 said...in the drill and wack it in reverse....my dewalt 12v does about 70km/h!!!
