for the guru's
https://forums.aussieveedubbers.com/threads/32462/for-the-gurus
phatrat ·
311.119.225.
Is this a type 3 engine number?
If so from what model and year?
Cheers Steve
squizy ·
It's a Type 3 motor from a Fastback. Not sure of year.
Have a check of this link....
http://www.aircooled.net/gnrlsite/resource/specgeninfo/partnumbers.htm
Squiz....
PurpleT3 ·
Where exactly was this no on the engine. The engine no itself on a type 3 is on the right case half, just in front of the fan housing. They follow a letter/number format eg U0XXXXXX, or T0XXXXXX or similar.
phatrat ·
PurpleT3 wrote:Where exactly was this no on the engine. The engine no itself on a type 3 is on the right case half, just in front of the fan housing. They follow a letter/number format eg U0XXXXXX, or T0XXXXXX or similar.
the number is on the fan housing, perhaps it's the part no for that.
will check again...not sure if it's a type 1 coverted to type 3...
PurpleT3 ·
Yep, that will be the P/N for the fan housing.
Check this out for a listing of engine and chassis no.s
http://vwtype3.org/info-serial-numbers
phatrat ·
OK! TO478648
7/67 fastback
1600 TP 12v
Correct? Yes/No
PurpleT3 ·
Yep looks about right. Built sometime after 7/67. To find out exactly what date the car was built you need the chassis no. I don't think engines had unique numbers, but I could be wrong.
phatrat ·
Thanks Steven
