Aussieveedubbers 路 Tech Talk
weird Tread Wear
https://forums.aussieveedubbers.com/threads/32463/weird-tread-wear
BiX 路
I have been having issues with weird tread wear on my rear tires. My old street tires, which spent 90% street 10% time on track had the wear pattern. I got the wheels alinged (slight toe in, same -ve chamber on the rear) and then used my race tires (90% race, 10% commute to track) and had the same wear pattern again
It happens under different presssures (from 25 to 45 psi)
any ideas?
below is a cross section of the tread and where pattern, the ridge is about 4mm.(outside is the left)
[Edited on 3-12-2004 by BiX]
Gibbo 路
I dont know anything about this happening (Hides angle grinder, hehehe)
馃檪
Bizarre 路
I had this on my FRONT tyres
stopped when i put my lowered struts with new inserts on.
How are your rear shockd???
:jesus
BiX 路
umm baout 3 yrs old, put them new when i got the car. kyb silver (gas?) mabye its time for some koni's.
jakjones 路
Overheated on outside edge,
could say 4 sure with a photo.
Possible remedies include more neg camber and or a tighter sway bar or a harder tyre compound , have u checked your rear alighnment u should have slight toe in about 1.5mm each side, if it is set on toe out , this may be part of the problem..
hope this helps..
Desert Moose 路
many year's ago, when Alan Grice was running that ute in the 12hr race in bathurst. Goodyear had the same problem it, turns out that its a weight V's force thing and the tyre suffers. because the car was so light in the rear but still had all the forces put sideways on to the tyre. I can't tell you any more then that because i was working for a different motorsport tyre manufacturer at the time. (which is now the same)
BiX 路
it happened on the falken st115 on the street, then on the toyo fm9r on the track. It runs about -1.5mm toe and about -1.35 degree chamber. checked the day before it happended. run std torsion bars , but with a 24mm sway bar.
