044 Heads, P and Cs...
https://forums.aussieveedubbers.com/threads/32616/044-heads-p-and-cs
AdrianH ·
Ok, I have decided to upgrade a bit so heres whats for sale...
Heads 044- CB CNC oval ports, Bugpack valves, Remmelle retainers, Bugpack springs, berg collets. 42 x 37.5 with a 90.5 bore and .040" copper head gaskets. Also comes with a complete set of new valves, dual springs and retainers and collets (single groove CB stuff).
Cylinders and pistons - Berg 90.5s (B's), balanced, total seal second rings, berg circlips.
Manton chromolly pushrods - bit of a scar on 1 or two, still in use with the above so fine to use as they are.
Sig Erson 1.45:1 rockers (I have measured this) and cup adjusters...
I have used all this stuff for the last 1200 miles (12 months). For the lot $ 1600 NZ plus freight .Engine is still in one piece, will pull to bits if someone is serious.
Currently I am lifting .555" at the valve using an 86B cam. Springs were shimmed off the head so no scarring has taken place.
AdrianH ·
Will split for reasonable offers...
Around 1000 for the heads
Around 350 for the P and Cs
Around 300 for the rockers and pushrods
