The head nuts on the left head of my 2 lt have loosened .Any idea what causes this ? I have checked and tightened the bottom 4 a couple of times .I now have the engine out and with access to the top 4,I find they have loosened to between 10 and 15ftlb.hence the farting noise.and loss of power.On reassembly can I put locktight or similar on the nuts to stop this?Or is there a better solution?Is this a common problem?The right hand side is ok.
On a Type 1 it is to do with the studs pulling out of the case. Usually solved with case savers - but i thought Type 4 would come with these already
Could also have something to do with the barrels cutting into the head mating surface.
Maybe something in the case barrel seating / barrels / head aint parralell and or flat
Locktight i dont think is the answer - I would suggest a trip to a machinist
Andy ·
Yep, as blue says.
Type 4 motors come from the factory with the head studs threaded straight into the case like a type 1, but with a fair bit more material, making pulling the heads studs less likely than a type 1 motor but still possible.
Loctite not likely to be the solution. As Blue says look at getting the head machined to ensure everything has a good surface to bed into when re-assembling, especially if the head has been leaking.
Another thing often over looked is CLEANED AND GREASED threads for the nuts to go onto. If they are dirty or dry, you can often have the head studs twist without tightening properly and they will soon loose tension. Also the original washers are large in diameter and quite thick so so they dont cut into the head. 😉
muz ·
Thanks for the replies
.What should the studs be torqued to into the case .Some seem a bit loose(under 10ftlb) The head went to a machinist about 18mths ago for the same problem(thru a vw mechanic).I've heard some heads can go soft ,or be soft. Is this true? and if so ,would the machinist pick it up?
most of the washers are about 2.5mm thick but 2 are thinner.all are the same diameter.
thanks again.
stevosky ·
yes some heads can be soft already. if they have been overheated. some machine shops will just machine a head flat instead of straightening it first.speaking from experience. it wasn't a vw head though.
Che Castro ·
The head studs need to be torqued in a particular pattern in a certain procedure. You alternate between left and right heads etc. It is outlined in the Bentley manual and Muir manual.
I didnt follow this when i first got my dub and learnt the hard way! Heads leaked exhaust everywhere and ran like dogs balls
Andy ·
A little late to reply, but the studs don't get torqued into the head. The threads run through the case and shouldn't be tight. Might be showing up that you have damaged threads in the case.
I have heard about "soft heads" but not sure if it's true. It's usually in relation to dropping valve seats or recessing valve seats in heads that have been rebuilt too many times, or over heated as stevosky said.
The thickness and hardness of the washer is just to stop the nut wearing into the aluminium.
