Aussieveedubbers 路 Tech Talk
Whitewalls?
https://forums.aussieveedubbers.com/threads/33075/whitewalls
chrisdebug 路
Hi I recall reading somewhere on this forum that there is a co. that does whitewalls in sydney? Appreciate if someone could point me to that link. Tks.
ByronBug 路
:sandrine
Try Ben at antique tyre supplies in Victoria
ph 9458 4433
Judy 馃檪
phantom 路
Bit of a distance but there is a guy here in Wagga who does them, haven't seen the work, he advertises in our club newsletter.
Tyre Art, phone 0408 897 278, Terry. From his ad, his white walls are 3/4 inch wide and he does them for $100 per set. He gives our members a discount, he probably would for other VW club members.
lugnuts 路
Cool Cruisin tyre whitewalling 02-9618-0137 or mob 0415-904-196 Kevin Owen 25-30$ a tyre for 3/4 inch or approx 20mm it takes 2hrs to do because he uses a machine to grind flat the tyre surface then 2 coats of paint,problem no.1 depending on your tyre how much of your raised tyre info will be ground off or worse half off and problem no.2 mine came out looking great for 2 days then it went to a grey colour due to something in the tyre leaching out,if you have new tyres you have to put 3000kms on them first and if you have EVER used silicone on your tyres FORGET ABOUT IT slater :kiss
chrisdebug 路
Thanks fellas. Appreciated.
