Am after an inline fuel pressure gauge. standard fuel line size. Anyone have one or know where i can get one????
Must be new or very good condition
Will pay postage etc
Many thanks
Dan馃槈
68AutoBug 路
I tried to get a loan of one to check the output of My electric fuel pump but no one seems to have one...
I did see one for sale somewhere but it was around $100...
as I only needed it to use Once... I thought it too expensive..
They are cheap in the US so I'm told... but then most things are cheap in the US...
Best of Luck...
Dannyboy 路
Seen them on a few cars over the years so must be available somewhere. Mmmm more info needed!
Dan馃槈
bond 路
dude, were you still keen to sell those decklid hinges?!
thanks nick
Dannyboy 路
Why of course sir , please come this way to u2u land.........
Dan馃槑:beer
Dannyboy 路
anyhow...........been searching for gauge but no joy yet , anyone..
dan馃槈
seagull 路
I have many > what is the pressure range and size dial you require , neil
seagull 路
you can have
40mm dial x 1/8 "bspt
50mm dial x 1/8 "bspt * around $32.00 each *
63mm dial x 1/8 or 1/4 bspt * around $38.00 each *
100mm dial x 1/4 bspt
all are rear entry brass internals ss case
I can get the VW logo on the face , need a order for say 20 units the same size .
you need to get a T peice and the compression fittings your self
[Edited on 24-12-2004 by seagull]
Dannyboy 路
Mmmm , was planning to put it just in front of t piece that goes off to carbs. After regulator. 5" sounds good would be mounted centrally in engine bay. Need all hardware
Is this easily fitted into the standard rubber fuel lines , like a fuel filter??
Cheers Dan馃槈
lugnuts 路
5 inch :duh
robnjo 路
I got a "Redline" one from "Revolution Race Gear" for about 20 bucks,give them ago. They have afew different brands too.
Rob
lugnuts 路
Hey Danny i dont think there sposed to be permanently connected,only to check correct pressure,OR SO IVE HEARD :kiss
robnjo 路
you can leave them connected but not set-up inside your car.
mine has been on my fuel line for 2/3 years, is kool I guess.
Dannyboy 路
Sorry 50mm one sounds okay but i'll do a search on the redline ones etc . I've seen them fitted to heaps of bugs etc. Rob do you run one??
Dan馃槈
robnjo 路
who me?...thats mine in the pic
Oasis 路
If it's a fuel pressure regulator you need Buy a Malpassi one. It's the only decent one made. call Carburettor Service Co ... 240 PARRAMATTA ROAD, BURWOOD NSW 2134 PH: 02 9747 4066.. about $100, but worth it.
[Edited on 26-12-2004 by Oasis]
Andy 路
I fitted a VDO brass one (black face) 0-15psi (for carbs, not FI). Can't remember if it was 1/8" Bspt or Npt. ~20-25mm diameter. More that big enough.
Bought from VDO distributor. Been on Andy for a few years now.
Can't find any pics sorry.
Richard
1303 路
I've got a 15 psi gauge fits inline and the T piece for the carbs and the hose and the Malpassi adjustable fuel pressure regulator. It is all about a year old , I am going to an injected motor so I have no need for it. Sell it all for $130.
ian.mezz 路
why??? if its not broken don;t fix it.:cussing
Dannyboy 路
1303 you have u2u.
Cheers Dan馃槈
1303 路
Picture of the regulator and T piece and Gauge. The gauge has a chrome steel surround and measures 55mm in diameter.
