Aussieveedubbers 路 Tech Talk
hub cap clips
https://forums.aussieveedubbers.com/threads/33472/hub-cap-clips
rusty 路
can anyboby tell me how to get the rivets out of the rim so i can change the hub cap clips.
pod 路
drill them out, just centre punch in the middle first and use a smaler drill than the rivet then you should be able to knock them out with a pin punch馃檪
sax 路
Wot he sed.
[Edited on 29-12-2004 by sax]
rusty 路
whot size drillbit do you recomend and can you dammage the sides of the hole
sax 路
You might make the hole a bit bigger, try a 1/8 to start.
pod 路
wot he ^ said 馃檪
64vwmark 路
Be careful of some of the new clips that you can get, they tend to be really brittle and you end up having to replace them more than once.
Andy 路
I think the holes are ~3/16" or there abouts. Start small and work up.
