which ATF ? does it matter?
https://forums.aussieveedubbers.com/threads/33575/which-atf-does-it-matter
muz ·
Can anyone tell me what type of auto trans fluid I should use in my 79 2lt bus. Does it matter ?It sounds like there is a couple of different auto boxes around,is this the case,not sure if mine is the original or not, as the engine isn't. How do I identify it?
PurpleT3 ·
The two auto boxes are the 003 and 010. Unfortunately my Kombi manual just says Dexron for both, it doesn't specify the grade of Dexron. Sorry.
Warrenm ·
Gregorys, Clymer, Autobooks, Intereurope and Haynes Manuals just say Dextron.
Haynes says your VW dealer will select best grade.
Warren
My Book says DEXRON 11..
muz ·
thanks all ...dexron 11
Andy ·
A similar post
http://www.aussieveedubbers.com/forum/viewthread.php?tid=28886#pid234614
kombikim ·
IN THE OLD DAYS it was dexron which was superseded by Dexron 11 which was superseded by Dexron 111 which will be superseded by? & different companies come up with different fancy names for their ATF
just make sure it says Dexron anything, somewhere in the fine print
