v6 T2 pics of radiator
https://forums.aussieveedubbers.com/threads/33664/v6-t2-pics-of-radiator
vwtyp2 ·
here's where the rad sits in my v6 bus.
the rad is from a hx holden v8.
it has a thermo fan on the back to blow air through.
[Edited on 4-1-2005 by vwtyp2]
vwtyp2 ·
there's a duct that sits behind the beam to direct cold air through the rad.
vwtyp2 ·
view of top of rad.
sits neatly between chassis rails, and on an angle so air passes through it easily.
vwtyp2 ·
here's another pic of the air duct.
sikdub ·
Hey man, nice set up. how much ground clearance would this sacrfice if any?
vwtyp2 ·
about 100mm.
you can see in the 2nd pic that the exhaust hangs dorn lower than the cooling.
this will change very soon though. 🙂
sikdub ·
Ta. It's wicked, very interesting
57 Chook Shed ·
Would I have any ground clearance issues if I fitted it to mine??
Alex Holzl ·
hahaha nar not at all!
vwtyp2 ·
should be o.k. Gra.
hangs down 100mm from chassis.
I can show you how, if you show me how to get down that low. 😉
57 Chook Shed ·
It`s easy, who needs all those torsion leaves!??
Klaus ·
hey thats how i had the vn v6 rad fitted but I couldn't relocate the outlets mmm , changing mine to up front as the kombi gets a lot of offroad use, also want to get a an all alloy rad due to the fact I burst the end plastic end tank one up on its second outing ( pretty common for these ones).
