Subaru Conversion ?\'s(where to start)
https://forums.aussieveedubbers.com/threads/33751/subaru-conversion-swhere-to-start
Urban_Squrill ·
First off I have a 72 bug. I have been reading up about doing engine swaps for awhile and it seems that a subaru motor is my best(cool) bet. I am looking at a EJ-20T I think it is a WRX motor. Where do I start? I have read some forums that breifly tell me about stuff. But what I am looking for is a write up of what I need to do like what to cut and such.
Also the tranny. Can I just get a beefed up one or do I have to get special ratios?
Any tips?
[Edited on 6-1-2005 by Urban_Squrill]
Doug Sweetman ·
Three guys are currently doing this (or in Jak's casse, just completed it) on the forum, their forum names are Boof2332, Jakriz and Steve1302. Any or all three of these guys should be able to give you some help, they are all very nice and helpful gentlemen.
Jak's first post about his conversion was called 'Its all stock', and he had another called 'Finished' or somthing like that. Try searching for them.
boof2332 ·
Where are you located.....I am in Sydney and you can come and look at mine whenever you like.
Matt
Urban_Squrill ·
I wish I could look at it, but I live in the States. This forum has the best info on doing a swap.
malcolm ·
try and by a front cut then you can use orignal wiring loom,ecu and other bits and when it needs a tuneup just go to a subi dealer. the rear of the inner wheel arches may need to be clearanced for the heads and the fire wall for the turbo and plumbing etc don,t forget about the ground clearance move the engine forward 1" or 2 helps with handling. is LEADING EDGE still operating in the states they had shorten sumps,reversed alloy water inlets and outlets and a few other trick parts they were also a haltek and motec ecu dealer.kennadys in the states allso have adaptor plates as well. hope this helps malcolm.
Urban_Squrill ·
How would you go about moving it forward? The great thing about having a subaru motor is that I am very good friends with the owner a dealership near me.
malcolm ·
you can reverse the gearbox front mount better still make a mount similar porsche use and a cradle to support the motor have alook at a 911 good for ideas. you have to stop flex will also save the gearbox.what gearbox are you using.
Urban_Squrill ·
I was not really sure but I was thinking about http://www.justveedubs.com/transconv.htm ? I know I need a new on. My bug is just my project car.
malcolm ·
get a porsche gearbox cheap from pelican parts in the states but no room for moving the engine foward without major mods go with a 915 box , 901 no better than a Lbug box.or go with a Lbug box with a good set a Albins gears from oz ,transform,rancho use these gear sets in their top boxes and a Modena diff torque biasing or disc type from oz as well better than quaife and with the us dollar cheap.
Urban_Squrill ·
I was under the impression that to get a porsche gearbox it would take a lot of work to get it to work,
malcolm ·
to do anything properly takes alot of work .I,ll try and post some web sights for you which will help.
baybuscamperkid ·
take a little looksie on http://frost.bbboy.net/vwengineconversions
malcolm ·
go to www.germanlook.com and their links are great to.
pete wood ·
just done one into a buggy, click on the geocities link below.
also, try the subbug user group on yahoo. lots of guys have them there.
you might like to read this too,
http://www.geocities.com/peterwood734/buggyproject/subarupower.html
[Edited on 8-1-2005 by pete wood]
