Complete Turbo Set Up- NEW LOWER PRICE
https://forums.aussieveedubbers.com/threads/33882/complete-turbo-set-up-new-lower-price
loco66 ·
Turbo System to suit T1- manx, beetle or kombi
complete system including
TO4 turbo, rebuilt and modified
Garret 32mm external waste gate
Dellorto 45mm sidedraft carb, modified and jetted
Deano manifold, modified dp manifolds & inlet pipe
Cast iron exhust manifold with thick flanges
Cast dump pipe with stainless exhuast
Water methanol injection, adjustable, boost sensitive, stainless tank
Fuel sytem, modified tank, malpasi boost sens. regulator, large carter electric pump. 1/2 inch fuel lines
All hoses and fittings, braided teflon hose
Reciepts for $$$$ 1000's
very streetable set up, tuned ready to bolt on
Has run 13.3 at 95mph on a 1600 in a beetle (15psi)
$ 2000----
Luke 0403 595640 gold coast
[Edited on 9-1-2005 by loco66]
[Edited on 14-1-2005 by loco66]
[Edited on 15-1-2005 by loco66]
loco66 ·
loco66 ·
loco66 ·
loco66 ·
loco66 ·
VWFOOL ·
can u post a bigger pic of it in the car, does the engine lid close ok?
is this everything to just bolt on and go?
11CAB ·
Here's a pic from Valla 01
loco66 ·
thanks for postin the pic!!!!
Luke
11CAB ·
So whats happening to the car now?
loco66 ·
Deck lid has stand-offs and sits out at the bottom, basically stepped back as much as at the top, keep in mind that this set up is really to suit manx, but looks tough on a beetle.
I removed all the rear apron but that was to make engine pulls heaps faster, Just a little trimming needed
This is seriously bolt in and make silly hp, i have spent $$$$ and mucho time setting up the carb properly and all the rest, if you had to buy all the stuff thats there it would be $ 5000 easy
i leave for o/s soon so snap up a bargin
Luke
loco66 ·
Body was sold recently, have reatained all the running gear. New top secret Steet/ drag project on the way when i get back from O/S...... still VW but very out there
New engine being built as well
luke
ruckus ·
Looks like it sits a bit lower than most turbo setups I've seen but looks cool. How legal is it, or is this a stupid question?
[Edited on 15-1-2005 by ruckus]
loco66 ·
Legal in wonderful sunny queensland
& will be legal in all other states if you look at the Engine capactity// Weight rules for turbos
See RTA/ Vic roads Etc
VWFOOL ·
so u hav to cut any metal out of the rear apron then?
twoguns ·
looks like in teh pic, it has a custom fab rear apron.
ruckus ·
Man if I could only stop spending money and save.... so I could spend money?🙁
